-   996 (https://www.6speedonline.com/forums/996-11/)
-   -   Help! Key won't open door! (https://www.6speedonline.com/forums/996/105757-help-key-wont-open-door.html)
PorscheEnvy Nov 12, 2007 11:22 AM
Hello,
I haven't drove my Targa since Sunday 11/4. This morning I had to get a few things out of the car, and the keyfob wasn't unlocking the doors, the hood, or the glass hatch. I thought maybe my battery died, though the security light was still blinking red, I tried to open the door with my key and that wouldn't work either. Do you think my battery is dead? It's only been 7 days or maybe my key got damaged or out of sync with the security system some how?
Any help is very much appreciated.
Thanks!
otherhwhitemeat Nov 12, 2007 11:38 AM
is the red light blinking on the remote when you press it? if so, take the battery out of the key- turn it upside down and put in back in the key- leave it in there for a few seconds- then put it back in the right way- the soft remote reset might work
PorscheEnvy Nov 12, 2007 11:43 AM
Thanks.. I'll give it a shot. Should I be in front of the car when attempting a soft reset?
otherhwhitemeat Nov 12, 2007 12:22 PM
shouldn't matter- hope that works - keep us posted
PorscheEnvy Nov 12, 2007 12:40 PM
Thanks again for your help. I'll try when I get home. So currently the red LED flashes, I tried removing the battery and waited about a minute and put it back in. It continues to flash with red whenever I push a button on the key. I've never really payed attention to this, but during normal operation, how should the key light up when a button is pushed?
Thanks!
otherhwhitemeat Nov 12, 2007 12:49 PM
light on key button should flash rapidly, so should the light near the sun sensor on the center of the dash board when the remote is pressed
Vik Nov 12, 2007 01:00 PM
If you put the key in the door it should open. It doesn't matter if the battery in the remote or car is dead. Do you have a spare key? Maybe the metal key is damaged.
otherhwhitemeat Nov 12, 2007 01:08 PM
I was under the impression that the key remote was the only part that wasnt working- not that you couldnt open the door at all with the mechanical key- if you cant open it with the mechanical key you got bigger problems and the above statement is correct- problems like a door lock actuator or a lock clyinder. Is it just the remote that doesn't work or the whole key? perhaps I misunderstood.
Vik Nov 12, 2007 01:26 PM
Well if we are talking about the remote, the alarm system will "go to sleep" when the car is not opened within a week or so (don't remember exactly how long). Once you open the car door manually (the alarm will sound) it will wake up and fob should work.
BigMac78 Nov 12, 2007 01:29 PM
Really?
This is scary, yet interesting. I leave my car in the garage for weeks at a time due to business travel. But, I don't lock the car when I leave. However, I have someone go to my house and start my car once a week and let it idle. If he sets the alarm after leaving then I could potentially be screwed...
Is there any documentation on this?
Thanks.
otherhwhitemeat Nov 12, 2007 01:35 PM
True- I think 7 days or so is about the norm- depends- but I still dont know if were are talking about an inop remote or a inop door lock
otherhwhitemeat Nov 12, 2007 01:36 PM
from orig post I am preety sure it just the remote portion
Vik Nov 12, 2007 01:40 PM
Thanks.
Huh?
I don't think you understood my post.
If the car is locked for +1 week without activity the alarm system will go to sleep. This means you will NOT be able to open the car with the key remote. HOWEVER, you can open the car by using the metal key and manually opening.
This is in the manual.
Vik Nov 12, 2007 01:43 PM
Just checked on renntech.org and the user stated the following:
Originally Posted by PorscheEnvy
I'm unable to open the door phsyically with the key. The red led is flashing. I was told you can remove the battery to try a soft reset, but after doing so, the red led still flashes. I never payed attention to it before, but how is the led on the key supposed to light during normal operation?
Thanks again!
Its a mechanical issue.
otherhwhitemeat Nov 12, 2007 01:56 PM
then messing with the remote, soft reset blah,blah blah :pisn't going to do any good- if the lock and the remote arent working its probably a busted door lock accuator-sucks.
