Possible to DIY diagnose check engine light?
Old Oct 1, 2004 | 02:13 PM
SpeedC2's Avatar
SpeedC2 is infamous around these parts
On my old E36 M3 I was able to check the codes by jumpering the diagnostics connector.
My check engine light is on in my 1999 C2. Is there a way to check the codes w/o taking it to a shop? Thanks.
Old Oct 1, 2004 | 11:33 PM
LVDell's Avatar
LVDell is infamous around these parts
Buy yourself and OBDII. You can get them from 100-200 on the low side depending if you want one that runs through a PALM or if you want one that can run through a laptop. I chose the laptop route and paid $100 for the software and cable. It sounds as though you might have one though. If so, see if the plug is the same (which is probably is) as your M3.
Old Oct 2, 2004 | 12:40 AM
WARDHOG's Avatar
WARDHOG is infamous around these parts
Thumbs up
Try these guys. I've had one for some time and it's a great litte tool to have.
Davis Carchip
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Jul 29, 2019 11:13 AM
Mini George
Jan 18, 2016 09:16 PM
