Battery dead, resesting stereo
Old Nov 8, 2009 | 12:04 AM
Elephant Chuck's Avatar
Elephant Chuck is infamous around these parts
Battery went dead and now the stereo is kaput. I know there is a code for this, but the car (99) was purchased used and I don't have the code.
What to do.
Old Nov 8, 2009 | 12:17 AM
asialors996's Avatar
asialors996 has a spectacular aura aboutasialors996 has a spectacular aura aboutasialors996 has a spectacular aura about
Becker N/A can get you the code
http://www.beckerautosound.com/
Old Nov 8, 2009 | 01:35 PM
scubadawg's Avatar
scubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to beholdscubadawg is a splendid one to behold
You can post a message at renntech with your serial number, and Loren can give you the key or call Becker but they charge you, I had 1 deck that the key gen didn't work and Becker gave me the key without charging me
Post your serial number of your Becker deck here, I have a Becker Key gen that I can try to give you the number.
Old Nov 8, 2009 | 02:50 PM
Where does one find the serial number? On the back of the unit?
Old Nov 8, 2009 | 04:14 PM
scubadawg's Avatar
First way
How to get your radio serial number?
CR-220/CDR-220:
Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right **** (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
Or, if the radio is out of the car the then the serial number is on the label.
CR-210:
Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of numbered buttons below display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
CDR-23 (or later):
These radios do not have a security code - that is, not that the user enters.
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. Only a dealer or shop with a PST2 or PIWIS tester can replace a MOST bus radio (i.e. CDR-23, CDR-24).
I get a WAIT in the display - what do I do?
You have to wait 1 hour - with the radio on and ignition switch on (or the car running).
Neither of the suggested numbers worked - what do I do now?
My program does not always work. It works maybe 95% of the time but I have no explanation why it doesn't always work.
You can try 2 digits different each time (and sometime that works). So if your code is 1013 - then try codes 2 digits different from that code (i.e. 1011, 1009, 1015, 1017. etc.)
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers do too.
If you have the becker deck removal keys remove the deck, serial number on the back
Becker Serial Number Location Guide
The first step is to remove your becker car radio from the car, you will then be able to locate the unique serial number required for decoding by inspecting the top and right hand side of the radio.
A typical example of becker numbers are as follows :
Type 1 has a split becker model and serial number such as
  • Model : BE0837 - Serial : Y1245784
  • Model : BE1122 - Serial : Y7654321
Type 2 has the becker serial number and model combined to form the complete serial number
  • Serial : BE411021234567
  • Serial : BE1234Y1234567
Old Nov 10, 2009 | 03:57 PM
My unit is a CDR-210
Model number is R3297
Serial number W5024924
Scuba if you can run that through the key gen that would be great!
Old Nov 10, 2009 | 05:13 PM
scubadawg's Avatar
Try this number, not sure it will work since this is a CDR-210 (older model)
7377
My deck has a serial number of 2872 so it gave me a code of 6837, which didn't work but I tried going 1 number up and down and 6838 work, you might have to up or down a few numbers. My spare deck, (I have 2- CDR-220) I actually had to call Becker, the tech was nice enough to give me the code over the phone without charging me.
The code gen works most of the time.
Hope it works,
Old Nov 12, 2009 | 11:29 PM
I had to try a few codes around that one to get it working.
Also, I found you have to hit the frequency tuning button after entering the code, or it does nothing.
Thanks for the help.
Old Nov 13, 2009 | 02:46 AM
scubadawg's Avatar
Hi Chuck
So you did your deck back up and running?
Old Nov 14, 2009 | 04:55 PM
Originally Posted by scubadawg
Hi Chuck
Yes, I did. Thanks
Old Nov 15, 2009 | 08:17 PM
dainiukass's Avatar
dainiukass is infamous around these parts
Boxster Radio Code Needed, cdr 210
i got 97 boxster need help with code
Model : BE2282 - Serial : v5010247
Old Nov 15, 2009 | 08:51 PM
scubadawg's Avatar
I'm not at my computer at home right now, when I get home I'll generate a code for you
Old Nov 15, 2009 | 11:11 PM
scubadawg's Avatar
Try this code: 2728
Old Nov 16, 2009 | 05:09 PM
dainiukass's Avatar
i try 2728 i did not work
Try this code: 2728
Old Nov 16, 2009 | 06:52 PM
scubadawg's Avatar
See threads above
My code was 1 higher, then what the code gen gave me, so try a few numbers above and a few numbers below, if that does not worl, then its' 1 of those you have to call Becker on, I had to do that with 1 deck I have.
