Fault code help!!!!
Old Feb 14, 2010 | 06:05 PM
gu9cci's Avatar
gu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond reputegu9cci has a reputation beyond repute
Fault code help!!!!
Just finish install new fabspeed x-pipe catalic converter and take the car for spin...
Check engine come on and i read fault code 62 and 66.
They are misfire damaging to cat.
What i should do?
What can be wrong?
Old Feb 15, 2010 | 11:48 AM
bjarne996's Avatar
bjarne996 is infamous around these parts
Hmm, you got me worried now.
Are all the lamda sensors connected? Are they placed in the correct order?
Did you disconnect the battery so that you started with a full ECU reset?
Old Feb 15, 2010 | 02:30 PM
gu9cci's Avatar
Well i didn't reset the ecu,so thats might be the problem...i will try that now and see what happend when i take the car for spin..
Old Feb 15, 2010 | 02:43 PM
bjarne996's Avatar
I would double check the lamdas while waiting those 20-30 minutes requried to ensure a full ECU reset.
Hope that it will cure the problem. Look forward to hearing if you feel any power increase
Old Feb 15, 2010 | 02:45 PM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Saw your post. Are you using a Durametric or a generic OBD. I have one more car I can set up on my Durametric. You have my number if you want to give me a call.
Doug
Old Feb 15, 2010 | 02:50 PM
gu9cci's Avatar
Hi Doug...thank you i have durametric.
Guys i take the car for spin after instalation yesterday and the sound and power is incredible...I have full Fabspeed exhaust system and it is crazy!!!!!
I just want to do the flash next couple of days to complete..:-)
I will post within couple of hours if the reset help..
Old Feb 15, 2010 | 04:07 PM
gu9cci's Avatar
Yea just got back from test drive and everything was fine until i open the throtle up to 6000 rpm and check engine come on again and missfire code again...
Old Feb 18, 2010 | 02:08 PM
gu9cci's Avatar
Ok i got my car back from shop and turnout being the coilpacks....
Old Feb 19, 2010 | 06:45 AM
mathism's Avatar
mathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond reputemathism has a reputation beyond repute
Was the coil pack a problem on its own or caused somehow by the cat change?
Old Feb 19, 2010 | 03:06 PM
bjarne996's Avatar
Can you give a guesstimate on increase in:
-power
-sound level
And, please also post your experience if/when you get an ECU upgrade.
I cant wait to get my x-pipes fitted
Thanks,
Bjarne
DLF
Cayenne Turbo
Oct 24, 2015 11:27 AM
1gr8e39
Oct 1, 2015 04:07 PM
davetherave
Bentley
Sep 11, 2015 04:15 AM
Nuke
Sep 8, 2015 09:09 AM
