Installed Shocks car still makes NOISE!
Old May 8, 2010 | 06:07 PM
gswc32's Avatar
gswc32 is infamous around these parts
What am I missing? Do I need to change the struct mounts? The noise seems to come from there on both sides... HELP!!
Old May 8, 2010 | 06:22 PM
Steve Germany's Avatar
Steve Germany is infamous around these parts
If you live where they use salt there is a bearing (race) that is between the spring mount and the body mount is the problem. There is no way to service the race without disassembly and replacement. Count on a full reallignment front as well.
Old May 8, 2010 | 08:36 PM
gswc32's Avatar
Although I live in Texas, we did have a crap load of snow!
Is that separate from the strut mounts? Do I look for a race bearing?
Old May 8, 2010 | 08:54 PM
chaud's Avatar
chaud is infamous around these parts
What sort of noise are we talking about here? and, front or rear, and when does it occur?
Old May 8, 2010 | 09:45 PM
gswc32's Avatar
Like a spring mattress in the front. I had the car up in the air and pin pointed it to the top of the strut. Mechanic assumption is that its the strut mount because the spring is not secure. Any ideas?
Old May 8, 2010 | 10:17 PM
ebcarrera's Avatar
ebcarrera is a name known to allebcarrera is a name known to allebcarrera is a name known to allebcarrera is a name known to allebcarrera is a name known to allebcarrera is a name known to all
I had some noise somewhat similar to what you are describing, it turned out to be the top spring coil rubbing on itself. Ended up wrapping the spring with a thin plastic and that fixed it. Not saying this is your issue but it is worth a look.
Old May 8, 2010 | 11:59 PM
gswc32's Avatar
Here's a detailed components picture. I think its the strut bearing... Help
Old May 9, 2010 | 11:22 PM
VIPR ETR's Avatar
VIPR ETR is infamous around these parts
Change the Strut Mounts
Old May 10, 2010 | 06:33 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
There is an interesting article in this month's Total 911 magazine on noise in 996 suspensions. Shows how to replace most of the bushings. Might be an interesting read for you.
Old May 11, 2010 | 09:36 AM
gswc32's Avatar
Thanks! Now after putting on chassis ears, it been determined that its the BALL JOINTS, the shop lubricated them and the noise stopped.
My issue is car only has 42,000 miles on it, Does that make sense?
Old May 11, 2010 | 12:19 PM
buzzm's Avatar
buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !buzzm Is a GOD !
one of my rear shocks is making a sqeeking/creaking noise
anyone have that problem (they are pss9's) i have read pretty much everything about these but havent heard of this type of noise
Old May 12, 2010 | 04:11 PM
EastBay's Avatar
EastBay is infamous around these parts
here is how I fixed my front squeaks, just drill and add zerk fittings and pump full of grease
Old May 13, 2010 | 05:32 PM
KAZ911's Avatar
KAZ911 is infamous around these parts
maybe they just aren't broken in and seated right yet
PorscheEnthusiast
Nov 13, 2015 02:23 PM
km90265
Aug 31, 2015 11:00 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
