Doing my frist oil change on this car. [which oil 0w40 or 5w40]
Old Nov 14, 2010 | 06:58 PM
Nine_Eleven's Avatar
Nine_Eleven is infamous around these parts
Doing my first oil change on this car. [which oil 0w40 or 5w40]
I'm not sure which to use. Mobil 1 0w40 or 5w40. I live in California, the temperature is aroun 50F-80F degrees. I'm not knowledgeable about oil weight.
Old Nov 14, 2010 | 08:23 PM
ericyingling's Avatar
ericyingling is infamous around these parts
my shop uses 0 40 in my car.
but I would have others weigh in too.
Old Nov 14, 2010 | 08:24 PM
also, I am in so cal.
Old Nov 14, 2010 | 08:26 PM
trisgale's Avatar
trisgale is infamous around these parts
Same as above, I'm in socal too
Old Nov 14, 2010 | 10:55 PM
max996's Avatar
max996 is infamous around these parts
Go 5-40 W, 0 is just to thin for our climate in CA IMO.
Old Nov 15, 2010 | 01:24 AM
How many quarts?
Old Nov 15, 2010 | 05:56 AM
max996's Avatar
9 if you drain it all, and leave your yourself time and get it level for it all to come out.
But add the last 1/2 quart over time, take time to read your stick as well and check your display and see where you at, it varies.
However I would use and trust the stick as my final reading for accurate indicator.
Last, don't overfill.
Old Nov 15, 2010 | 06:38 AM
rb101's Avatar
rb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to beholdrb101 is a splendid one to behold
I use 5W40 in central FL.
Old Nov 15, 2010 | 03:32 PM
wyovino's Avatar
wyovino is a jewel in the roughwyovino is a jewel in the roughwyovino is a jewel in the rough
There are many discussions about this on various boards. My mechanic, who races Porsches, recommends Motul 5w40, and that's good enough for me.
Old Nov 15, 2010 | 06:10 PM
ClickClickBoom's Avatar
ClickClickBoom has a spectacular aura aboutClickClickBoom has a spectacular aura about
5w40 Syntec
Old Nov 15, 2010 | 07:05 PM
XLR82XS's Avatar
Pentosin 5W40.
Old Nov 15, 2010 | 07:13 PM
max996's Avatar
Cool
Valvoline synpower 5W40, $4.99 a qt,at NAPA, and sign up for Valvoline 300.000 mile engine guarantee for free, go online for their details, mine is going to last forever.
Old Nov 16, 2010 | 10:48 AM
fourempties's Avatar
fourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond reputefourempties has a reputation beyond repute
Interesting. Can you give us details on this?
Old Nov 16, 2010 | 12:14 PM
BigDaddy's Avatar
BigDaddy is infamous around these partsBigDaddy is infamous around these parts
Castrol Edge Formula 10W 60.
All german tuners use that oil in their Pcars. Especially when u live in Cali u dont need a 0W oil.
Greetings from Hamburg
Old Nov 16, 2010 | 12:24 PM
Slider's Avatar
If this is really your very first time changing oil in your "P" car, I feel I must mention the little issue of the size of your drain pan...
The pan must be able to capture about 8 liters of oil within 2 seconds because that's how long it takes to empty the whole thing and if you are using "standard" oil draining hardware, you will become a member of the "Valdez" club. This is not a joke!
