Need 996 Engine Rebuild in Dallas
Old Dec 17, 2012 | 07:55 PM
  #31
BiteEmNBeatEm's Avatar
BiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud ofBiteEmNBeatEm has much to be proud of
who is doing the rebuild from a 3.6 to 3.8? I'm gueesing your going to take the 96mm bore out to 99mm right?
Old Dec 17, 2012 | 08:25 PM
  #32
txhokie4life's Avatar
txhokie4life is infamous around these parts
Ouch, that hurts.
Sounds like the root cause wasn't found the first time around.
When you tore it down did you find the any of the chains off?
Any of the pads/guides worn?
Were all the tensioners working properly.
LNE via Millenium Technologies does our 3.8L conversions, but its not cheap.
They do a billet aluminum liner, install, then plate it with Nikisil.
Mike
Old Dec 17, 2012 | 08:46 PM
  #33
gswc32's Avatar
gswc32 is infamous around these parts
First time IMS failure, second time Valve keep failure. I believe to have one bad valve and not sure if pump is bad. Found metal in filter.
What's my best option?
Old Dec 17, 2012 | 08:56 PM
  #34
Depends on the year -- have to check that the IMS sprocket didn't shift.
The sprocket is press fit on some years and can rotate around.
When your IMS failed originally -- it's possible that the sprocket, tensioner, or paddle was damaged.
Its also likely that the far end of the tube was damaged -- when the IMS bearing fails,
the tube wobbles and this damages the far end -- which could cause issues with the pump as well.
you have to tear it apart to investigate.
Mike
turbotuner20v
Sep 11, 2015 12:02 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Sep 8, 2015 09:41 AM
orbelo
Aug 30, 2015 12:26 PM
PelicanParts.com
996 Vendor Classifieds
Aug 25, 2015 03:31 PM
The Oss
Aug 24, 2015 08:19 PM
