Need mesh screen for center nose opening...
Since installing EVO Supercharger on my car, I now have an opening in the center of my Techart Type II front nose piece where the induction hose had to be run. I would like to add a black mesh screen to match the ones that cover the openings (slightly smaller than turbo openings) on either side of it. Anyone know where I can buy this piece or do I need to get a piece of screen and cut and install myself? Thanks for any help.
Regardshttps://www.6speedonline.com/gallery...cat=500&page=1 |
License plate bracket has been removed.
You should be able to find it/order it at any local tuner type store. You can specify the type of mesh you would like (diamond/octagon and color typically black or white etc) and they will should be able get it in and possibly cut the pieces for you. Its not to expensive either. I had it installed on my old A4.
Elusive - who did yours?? I want somehting in the same pattern as the mesh on the new Gallardo
topspn, what brand headlight covers are those?
Msindi
Im not sure what the mesh pattern on the Gallardo is, all i did was call around to local store's here in Calgary until I found one that carried the mesh. I think its quite popular with the import tuner crowd so if you call one of the stores that caters to them they should carry it. You can also find it on Ebay they sell mesh in sheets for very cheap. (although im not sure how good the quality is) |
AC 996C2
Headlight covers are Techarts.
Regards |
