996tt Knowledge Base
codes 0491 & 0492
Old May 7, 2025 | 07:01 PM
bushrat's Avatar
bushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond reputebushrat has a reputation beyond repute
codes 0491 & 0492
2004 996 turbo X50 cab Check engine light on, indicating a problem with the secondary air injection system. Anyone know the location of any fuses or relays pertaining to this system? Any input greatly appreciated.
Old May 8, 2025 | 05:35 AM
maxrod's Avatar
maxrod is infamous around these partsmaxrod is infamous around these parts
I have read there is a relay. Location varies from coupees vs cabs I am told. In my case with a cab, I believe the relay is next to the ecu and yours might be the same.
Old May 8, 2025 | 08:40 AM
bushrat's Avatar
Thank you for your response. Have the roof/shell in the service position and the bank of relays exposed. Any idea which relay would be the culprit?
Old May 8, 2025 | 03:27 PM
maxrod's Avatar
I can only tell you where mine (I think is located) Attached photo is what someone p[osted a few weeks back. Take a look around and see if you something similar. I would start if you have a coupe, pulling the carpet back from the rear where ECU is located and see
Old May 8, 2025 | 04:53 PM
bushrat's Avatar
Thank you, this really helps !
Geflackt
Nov 22, 2024 05:29 AM
stanm5
Mar 5, 2010 07:42 AM
chrisf1965
Jul 1, 2009 10:11 PM
