PSS10 Damptronic's now shipping! **Limited Stock**
Old Oct 29, 2007 | 10:25 AM
Josh/AWE's Avatar
Special Intro Price for 6speed readers! Please EMAIL ME for more info. NO PM'S PLEASE!
I am leaving for SEMA tomorrow, but will do my best to check emails. I will not be checking 6speed.
mike@awe-tuning.com
You have been reading about them, now they are here. Direct replacements for the OEM PASM suspension.
The most frequently asked questions are the following:
1. Are there external adjustments on the shock? No, You retain the sport suspension button on your dash. This will change it from the softer to the harder setting.
2. Are they height adjustable? Yes, these are just like any other coilover. The shock has a threaded body with spring perches that will allow for adjustment. Great for setting the ride height, rake, and corner balancing.
3. Will I get any error lights on the dash. No, this is completely compatible. Bilstein has the most intimate knowledge of this system due to the fact Porsche contracted them to help develop the OEM system on the car now.
Please visit our website for further details.
http://awe-tuning.com/pages/shared/p...nsion&IL=pss10
Old Oct 29, 2007 | 10:56 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
Ohhhh Yesssss!!!
Old Oct 29, 2007 | 03:43 PM
ALPINE_997's Avatar
ALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to beholdALPINE_997 is a splendid one to behold
Mike,
Thank you for the GREAT service you provided! Got a tracking number?
Gene - did you get you a set?
I ordered mine already and should get it Wednesday/Thurs.
Also I found a TA front for the Rear TA piece I got.
Old Oct 29, 2007 | 05:03 PM
eclou's Avatar
I can never say no to Mike
Old Oct 29, 2007 | 05:20 PM
ALPINE_997's Avatar
yeah Mike can twist pretty hard at times
Old Oct 29, 2007 | 06:04 PM
cannga's Avatar
Hi,
Any comment please on the "noise" reported in this forum on the other thread? Thanks.
https://www.6speedonline.com/forums/...=101378&page=2
In the first photo you will see the complete system as it ships from Germany. In the three additional photos, you will see the PSS10 utilizing cup car mounts. The cup mounts are the silver ones and the stock mounts are black. The cup mounts add more flexibility for adjusting camber and provide improved spring rotation during a tight turn. Due to the angled shape of the stock mount, a slight popping sound may be heard when making very tight turns at slow speeds, such as turning into a park or garage. The angle of the mount causes the "pop" as the spring rotates in the mount while making the turn. That's not a desirable noise from a $150k car.
Old Oct 29, 2007 | 07:01 PM
ALPINE_997's Avatar
On my H&R springs I got a tension release sound from the top of the spring which I would assume is from the perch area. It would only happen when I turned the wheel all the way to one side or the other and it would kinda pop in or out of place for a second and then it was gone.
When I install these I will listen for it to see.
Old Oct 29, 2007 | 07:21 PM
TurboBill's Avatar
TurboBill is infamous around these parts
Originally Posted by cannga
Hi,
If you compare the photo that Mike posted above of the Bilstein's vs. the photos that 997TT posted of the "complete system as it ships from Germany", it looks like the ones that come from Germany do not come with any mounts while the coliovers Mike is offering do come with Bilstein supplied mounts. Maybe this is one of the reasons why Bilstein took so long to offer these in the US while the Eurpoean Companies have had them for several months???
Name:	997TT from Germany.jpg
ID:	52298   Click image for larger version
Name:	Mike AWE Pic.jpg
Old Oct 29, 2007 | 07:32 PM
WildBill's Avatar
WildBill is infamous around these parts
They do look different than the PSS10 set I just installed. Maybe the "damptronic" is a newer upgraded version. I look forward to the write ups!!!
Old Oct 29, 2007 | 07:40 PM
WildBill's Avatar
Alpine, do you have any leads on the Techart front and rear lowers? I really like them.
Old Oct 31, 2007 | 01:54 PM
cannga's Avatar
Mike (or any expert here),
Could you please explain why the springs don't look the same in these 2 systems. The one from 997TT has a little spring and a big spring, the one from Mike/AWE only has one big spring.
Isn't that little spring part of the progressive rate feature of the Bilstein Coilover?
Old Oct 31, 2007 | 02:51 PM
ALPINE_997's Avatar
Can,
The little spring that you see is usually called a helper spring. It keeps the main spring indexed or in place when its lifted up or or when the car is airborne for a moment.
We don't have that here with the US version thus we have different mounts to keep the spring indexed or in place for the same situations.
Anyone please correct me if I am wrong. I haven't opened my box yet but I will take actual pictures tonight of the coilovers.
Old Nov 2, 2007 | 04:17 PM
eclou's Avatar
I opened my box.
1)2 springs with each corner, 1 is a helper spring
2)each spring end has a flat beveled surface to ensure it will not "pop" when turning
3)the front dampener has the PASM wire enter thru the bottom of the strut instead of the top like the stock units
4)new sway links are included
This is a very high quality set - each dampener even has a "Nurburgring Tested" sticker on it!!
Old Nov 2, 2007 | 05:31 PM
WildBill's Avatar
eclou, your description sounds just like the set I received from Germany. Any photos?
Bill
Old Nov 2, 2007 | 05:38 PM
cannga's Avatar
Hello eclou & Alpine,
Thanks.
Another question: If I **don't** want to lower the ride height, does the PSS10 offer any advantage over the stock coilover? In other words, does it offer better or firmer ride/handling, allow more adjustments with camber/toe in/caster, etc., even if I plan to keep the car at stock height? I assume you would need to install it first before answering, but I guess the question is what are the expectations?
I am new to this, please explain with as much details as possible. Thanks again.
