How can I tell if Sport Chrono Overboost Works?
Old Mar 23, 2008 | 07:34 AM
Emor8t's Avatar
Emor8t is infamous around these parts
Originally Posted by Barrister
Huh? It doesn't take any longer to check the boost gauge than it does to check the tachometer when switching gears - or do you do that by using the force?
Umm... you still have to look at the tach to know when to switch gears? I'm with the other guy, when the pedal is down my eyes are on the road, my ears let me know when to shift.
I can't imagine going WOT in a car with twice as much power as mine and taking my eyes off the road for a split second.
Old Mar 23, 2008 | 08:23 PM
crd's Avatar
crd
crd is infamous around these parts
Hey, come on, guys. I don't think anyone is suggesting glueing your eyes on the gauge then flooring it 1st gear. That would be simply stupid. Nor would it be wise to check overboost function on a sweeping turn.
Just like 2K7997TT said, get on the freeway or any other open road, get up to 50-60 in 6th gear, mash it. Don't worry, even 480 HP is not going to get out of your control. Under such a load, the turbos should try to spool up maximally and you should notice the little up arrow.
If you have any concerns, let the dealer check it out for you.
Old Mar 23, 2008 | 10:00 PM
Barrister's Avatar
Barrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to beholdBarrister is a splendid one to behold
Yes young padawan. I see the force is strong with you.
As for me, and most others not schooled in the ways of the Jedi master-Mazda, I need to check my RPM gauge now and then. I think that may have been on Porsche's mind when they put it in the center and made it larger than the rest of the gauges. Leave it to Porsche to design a car for those of us with fewer metachlorians.
But I would never seek to defy your Jedi greatness . . .The force will be with you, always.
PorscheEnthusiast
Nov 13, 2015 02:23 PM
MurderedTurbo
Aug 28, 2015 09:06 AM
phil_m
Aug 26, 2015 03:08 AM
vbb
Aug 21, 2015 10:17 PM
ppwchiang
Aug 20, 2015 10:28 AM
