1/4 mile speed - my 690hp 997 turbo
Old Apr 24, 2008 | 05:18 PM
DERBOOST's Avatar
DERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of lightDERBOOST is a glorious beacon of light
Originally Posted by jnixon
The racetrack was in San Antonio Texas. The biggest negative was the wind gusts that were up to 20+mphs
625 feet for san antonio dragway, so at a worst case your at maybe 3000 feet rel. Thats not such bad air.
Old Apr 24, 2008 | 05:25 PM
jnixon's Avatar
Awaiting Email Confirmation
jnixon is infamous around these parts
Wind and the Clutch
the wind definetly played a factor because it was really blowing against the car. The 997 Turbo has Evo intercoolers, boost hoses, headers with ceramic coatings and Giac software with the race tune. I admit that I was afraid to push the car and wanted to know what I should expect with that horsepower potential. I will track the car on a better day. How much can you push the clutch without ruining the pressure plate? I would blow the pressure plate on the clutches of 80s mustangs. I would speed shift and could really get going but sacrificed the clutch. The dealer said you will ruin the clutch doing burnouts with the car.
Old Apr 24, 2008 | 06:02 PM
dk996tt's Avatar
dk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud ofdk996tt has much to be proud of
Originally Posted by jimmer23
Should definitely be over 130mph regardless of your 60'. Your 1/8th should be over 100mph as well. What fuel were you running?
i don't think i have ever seen a 997 turbo trap over 130 mph with modded vtg's. i think most people were typically in the 126 - 128 area.
Old Apr 24, 2008 | 06:23 PM
heavychevy's Avatar
If 690 is supposed to be the power output, it should trap 130's. If 690 means something else, then yeah, maybe that's right.
Old Apr 24, 2008 | 06:44 PM
dk996tt's Avatar
i agree, if it is truly 690, it should trap 130+. just stating that all the 690 or 700 numbers posted to date have been in the 126 - 128 range.
Old Apr 24, 2008 | 07:46 PM
jimmer23's Avatar
jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !jimmer23 Is a GOD !
I was referring to the "690" moniker. It should trap 130+ like a 690hp car then - if not then what does it mean?
Anyway, even a 600hp TT will do 100mph in the 1/8th. Something's not quite right here...
Old Apr 25, 2008 | 02:10 AM
GT RUS's Avatar
GT RUS is just really niceGT RUS is just really niceGT RUS is just really niceGT RUS is just really niceGT RUS is just really nice
For 690HP 997 TT I think is very very HIGH times...I thought that you could run run high 10s with this set up like some of 996 GT700 did ??? Weird...I want my 997 TT to be much faster then my E55
Old Apr 25, 2008 | 04:39 AM
jamie furman's Avatar
jamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond reputejamie furman has a reputation beyond repute
I don't think the HP could be over 600hp, as my 540hp GT2 (Giac tune with evo wastegate acuators and muffler) runs 10.8, 10.9 between 128 and 130mph consistently. I do think if you can get the 60' in the 1.9, 1.8 range you will pick up .4 or .5 tenths and 4 or 5mph on your traps.
Old Apr 25, 2008 | 04:49 AM
LUISGT3's Avatar
Evo's car ran a 10.8 at 129 with the same mods.
My buddy also ran an 11.4 at 121 with a stock turbo.
You got some work to do.
Old Apr 25, 2008 | 08:04 AM
heavychevy's Avatar
Jamie, you have a different motor, ~400 less lbs, RWD and LSD. So you should expect to do more with less. Not to mention, the motors are completely different. And you run at the best Trap Speed tracks in the country. I dont think we've seen a 128 from a stock Z06 come from anywhere else.
I think we are starting to see some big dyno numbers from the 997 TT, but nothing from the performance side yet 60-130's, 1/4 mile to substantiate them.
But it's actually possible for his trap speed to go down with a better 60'. You wont gain 4 or 5 mph with a faster 60' assuming all else (shifting) the same. Unless the car lags real bad in 1rst gear.
Old Apr 25, 2008 | 11:00 AM
jimmer23's Avatar
^^^ What he said. Trap speed will slow down with a better launch and quicker ET. My 11.4 was at 123.33, and my best mph of 126.50 was like a 12.1.
Old Apr 25, 2008 | 03:17 PM
Duane's Avatar
Duane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud ofDuane has much to be proud of
That seems very slow, my 2002 X50 with stage 4 ran 11.9 at 120 my first time at the strip. Here is the video from almost 5 years ago, this was before I put the GT700 in. I had a run that was a little better I think 11.6 at 123, I will see if I can find that video.
Duane
http://www.youtube.com/thenew997
Old Apr 25, 2008 | 05:18 PM
jnixon's Avatar
Clutch
I need to know how hard I can push the sachs clutch. I am confident the mods are working I just need to get on it. Considering the money I have in the car I was nervous to speed shift the car and push the start. I will do this again and I am sure I will trap better times. I just want to know what the top speed should be for this kind of horse power.
Old Apr 25, 2008 | 05:21 PM
heavychevy's Avatar
Now that does make sense. Slow shifting can cost you a few MPH. especially on turbo cars if you are having any lag.
Old Apr 25, 2008 | 05:25 PM
jnixon's Avatar
Close gears
I read that the ZO6 can go almost 60+mph in first gear which would help the car in the 1/4 miles because of the limited amount of shifting. During the 1/4 mile run a driver in a 997 turbo has to shift 1-4 gears which could produce a lot of lag. Also if you do not shift at the optimal level this will affect the outcome. What is the best RPM shift point.
