Porsche 997TT 2007 - fitted with 2008 2nd Generation LED Rear Lights - UK
Old Oct 5, 2008 | 05:19 PM
Philly997TT's Avatar
Philly997TT is a jewel in the roughPhilly997TT is a jewel in the roughPhilly997TT is a jewel in the rough
Same here!! I can only imagine what the final cost will be after new taillights.
Old Oct 5, 2008 | 09:31 PM
PbPedis's Avatar
PbPedis is infamous around these parts
Looks great, but not worth the $ to me.
Old Nov 13, 2008 | 11:57 PM
SRatha's Avatar
SRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud of
If am living no where near a Porsche dealer to activate the control unit, it won't be possible to do this mod?
Old Nov 14, 2008 | 12:37 PM
Vorsteiner's Avatar
Vorsteiner has much to be proud ofVorsteiner has much to be proud ofVorsteiner has much to be proud ofVorsteiner has much to be proud ofVorsteiner has much to be proud ofVorsteiner has much to be proud ofVorsteiner has much to be proud ofVorsteiner has much to be proud ofVorsteiner has much to be proud ofVorsteiner has much to be proud of
We will be offering a facelifted version of our New V-RT rear bumper cover to accomodate the new LED tail lights in January 2009 for all 997 Turbo models.
Old Nov 15, 2008 | 12:55 AM
Green Turbo's Avatar
Green Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to beholdGreen Turbo is a splendid one to behold
I am planning to do just the rear retrofit next week. I will let you guys what it entails.
Old Nov 15, 2008 | 02:49 AM
BRN 997 TT's Avatar
BRN 997 TT is infamous around these parts
Originally Posted by gormanlad
To add Gen 2 LED.s to a Gen 1 Turbo you need the following:
1) 2009 Turbo front control unit ( 2no connectors will required moving)
2) Gen 2 rear control unit ( no wiring changes)
3) 2no rear gen LED lights ( they fit onto existing plug but a smal lug needs cutting of the new lights)
4) a Good body shop to modify rear bumber
5) A Porsche dealer to activate LEDs on front & rear control units
Hope this helps anyone interrested in modifing
Would you please be kind enough in giving us the part numbers for the above mentioned part.....
Old Nov 15, 2008 | 02:52 AM
BRN 997 TT's Avatar
It sounds really good, but any pic's or even a teaser??? for us to get a glimpse in how the rear bumper would look like
Old Nov 15, 2008 | 04:52 AM
knightka's Avatar
knightka is infamous around these parts
second the request for pictures
Old May 9, 2009 | 09:47 AM
reymusic's Avatar
reymusic is infamous around these parts
gormanlad,
Ive been told by suncoastporsche this is what happen after installing the lights.will i have the warning light on the dash?
I now have the front and rear control units in stock, the pair would be $366.88. Once installed, the lights will work but a warning light will be displayed on the dashboard
We're trying to find what wiring/pin modifications are required to remove the warning light. We don't have this information yet.
Once the lights, control units, and wiring upgrades are installed, a dealer should be able to activate the LED program in the cars ECU.
Old May 9, 2009 | 03:37 PM
gormanlad's Avatar
gormanlad is infamous around these parts
Do you get warnings for all light operations or just indicators?
Old May 9, 2009 | 04:13 PM
reymusic's Avatar
I do get warnings for all rear light operations..I don't have the front module install yet.I want to know after I have the 2009 front unit and the led rear control unit will my warning lights go away and the lights will work properly?I think I'm the first person that's doing this modifications on the 997tt in miami florida..they are not familiar with the setup yet..
Old May 9, 2009 | 04:20 PM
gormanlad's Avatar
Yes they will stop, Are porsche reprogramming the modules? I think I was one of the first in UK to convert,
Old May 9, 2009 | 04:22 PM
reymusic's Avatar
I do get warnings for all rear light operations...I dont have the 2009 front control unit install yet.I want to know after I install both front and rear module controller will I still have the warning lights?I think I'm the first one doing this midification in miami fl they are not too familiar with the setup yet..
Old May 9, 2009 | 04:42 PM
reymusic's Avatar
will the technician at Porsche dealership will know about the 2no pins that needs to be remove on the front modude?do you know witch one exactly?just trying to get more information...thank you
Old May 10, 2009 | 12:58 PM
gormanlad's Avatar
on mine i had to change pin B14 to B34 & pin B6 to B21 these are for the rear indictors you must get them to check wiring diagram for year car and the new module. it may be the same i cannot say for sure
good luck
