Hi Octane fuel and Effects on Aftermarket Exhaust Systems
Old May 12, 2009 | 07:15 PM
QUIK 911's Avatar
QUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to beholdQUIK 911 is a splendid one to behold
Originally Posted by BADBRUNO
I'll go back and check if it was leaded or unleaded fuel the pumps are right next to each other.. What does leaded fuel do to the cats?
Leaded fuel will kill your cat
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
Going back to check the pump is a good idea. You might have mixed up the leaded/unleaded gasolines or it is possible the track mixed them up when filling the tanks. Lead irreversibly fouls the cats preventing the intended chemical reactions and sometimes even causing decreased flow. Lots of us run 100 octane unleaded without issue.
Old May 12, 2009 | 07:18 PM
BADBRUNO's Avatar
BADBRUNO is infamous around these parts
Sparkhill
The dealer is telling me that there is an efficiency / flow problem in the cats.... This must be the problem!!!
thanks for you reply
Old May 12, 2009 | 07:45 PM
sparkhill's Avatar
Stating the brand of exhaust you own might allow others to chime in with options. I believe Fabspeed is the only modular exhaust and all of the others will probably require you cut out the old cats and weld new ones in. As suggested earlier, that would be a lot cheaper than a whole new exhaust. You might have better luck at a local independent shop or at one of the tuners near where you live rather than the dealer.
I recently ran across the quote," Porsche, the gift that keeps on taking." I think it fits for most of us.
Old May 12, 2009 | 07:53 PM
BADBRUNO's Avatar
I just liked at your photos, nice shots ! What pipes are you running with, tips and which exhaust?
Old May 12, 2009 | 09:05 PM
TT Surgeon's Avatar
At least tell us what the exhaust rhymes with.....
Old May 12, 2009 | 10:07 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
a quick post search reveals "Bill Tech"
Old May 12, 2009 | 10:29 PM
QUIK 911's Avatar
lol, now we all know who has the brains on this forum
Old May 12, 2009 | 11:12 PM
Tech1_Mike's Avatar
Tech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond reputeTech1_Mike has a reputation beyond repute
Lead and Manganese (MMT) are the two most common cat killers. They coat the reactive surfaces in the converter, destroying them.
The only cure is a replacement.
IMHO, someone caused one of these two agents to be introduced into your fuel tank. A little Sherlock Holmes work and maybe a chemical test will find the culprit.
Old May 12, 2009 | 11:31 PM
sparkhill's Avatar
If you were referring to my car, I have the Cargraphics Loud exhaust with the black Fabspeed tips, which I believe are exactly the same as the EVO tips. The tips will fit just about any exhaust.
Old May 13, 2009 | 06:42 AM
BLKMGK's Avatar
Question
After driving it for a bit were the exhaust tips a bit white, a little chalky maybe? If so the gas was leaded. This isn't usually an issue for the O2s as they can clean themselves if not poisoned repeatedly but for a catalytic it can be fatal.
If it wasn't lead it's remotely possible that the ECU mapping wasn't adjusted for the octane and that the timing wasn't advanced enough. higher octane burns more slowly and if too little timing is onboard you'll still have a reaction going in the cylinder when the exhaust valve opens - the exhaust overheats and can also trash the catalytic. This would be pretty rare though IMO, I'm betting it was leaded and if you saw a chalky residue on your exhaust you'll know for sure.
Old May 13, 2009 | 07:45 AM
summoboy's Avatar
summoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nicesummoboy is just really nice
lol - I got it. Plus a GIAC ecu upgrade.
"997 TT, with about 10K miles on it with 100 cell cats and GIAC ECU, nothing but perfect<!-- google_ad_section_end --> "<!-- / message --><!-- sig -->
Old May 13, 2009 | 07:51 AM
BADBRUNO's Avatar
perfect call
Your are Right on the Money yes I did see the white chalk and I have determined that It was 110 octane Leaded fuel Mt fault at the track!
What's the best fix?
I'm getting P0420 error
Has this damaged the lamda sensors? I'd
I have been told that the ecu can be programed to defeat the ox sensor fault
Or replace the exhaust system $4000
What do you think?
Old May 13, 2009 | 08:07 AM
BLKMGK's Avatar
The cats are likely toast, the O2s can often survive a little lead, especially when run on regular gas afterwards. Sadly I think the catalytics will not come back - sorry about that
Old May 13, 2009 | 08:47 AM
summoboy's Avatar
New cats!
