Hissing sound (like air escaping) from engine bay upon start up?
Old Jul 7, 2009 | 12:31 PM
E55AMG's Avatar
E55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud of
Any ideas? Last couple of times I drove the car I noticed upon start up a hissing sound like air escaping from something. If I open the hatch It seems like it's coming from the left side of the engine bay.
When I come back from the ride and open up the hood the sound is gone. Any ideas what it could be?
Old Jul 7, 2009 | 12:52 PM
rmx12's Avatar
rmx12 is infamous around these parts
maybe its a snake.
that would explain why the sound is gone after your ride
Old Jul 7, 2009 | 12:55 PM
The Fixed Roof.'s Avatar
The Fixed Roof. has a spectacular aura aboutThe Fixed Roof. has a spectacular aura aboutThe Fixed Roof. has a spectacular aura about
DOes the car stumble at idle?
Vaccum leak? Hose off of the valve cover area or PCV system somewhere?
Old Jul 7, 2009 | 01:13 PM
bbywu's Avatar
Chris, do you have a aftermarket intake or filter element? It is often louder after installing these.
Any loss in boost pressure at WOT or CEL's? Give your intercooler hoses and Y pipe a good shake as it goes into the TB (although at idle there shouldn't be much air flow in these.)
Old Jul 7, 2009 | 01:29 PM
Nico's Avatar
Nico is infamous around these partsNico is infamous around these parts
i get the same sound at a cold start. usually it stops when the car is warmed up and ready to go.
Old Jul 7, 2009 | 02:31 PM
E55AMG's Avatar
Bob, no aftermarket intake or filter. No CEL's either. Haven't checked for differences in boost but car seems to be running fine.
Old Aug 1, 2009 | 12:03 PM
Jonnydeep83's Avatar
Jonnydeep83 is infamous around these parts
Any update.. i have heard the same thing recently..
Old Aug 1, 2009 | 12:58 PM
E55AMG's Avatar
dealer said it's fine.
Old Aug 1, 2009 | 04:07 PM
gmoney's Avatar
totally normal, airpump throws air into the exhaust at startup to reduce hydrocarbons.
Old Aug 1, 2009 | 04:21 PM
SRatha's Avatar
SRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud ofSRatha has much to be proud of
I had a similar problem (intercooler hoses loose). In hard acceleration the hoses couldn't keep up with the pressure and just disconnected. the engine kept shutting down, but once all the hoses were all done rght, it was perfect again. I think in you case if the dealer said its fine, shouldn't be a problem, but I would check for a tear in the hoses.
Old Aug 3, 2009 | 10:11 AM
omes's Avatar
omes is infamous around these parts
Bingo! Secondary air pump. Pumps extra air into exhaust until the cats heat up sufficiently, done to reduce emissions as the engine does not run as efficiently on cold starts.
Old Nov 22, 2019 | 07:27 PM
Shane King's Avatar
Shane King is infamous around these parts
yes what you thinking
Old Nov 22, 2019 | 07:30 PM
Shane King's Avatar
It
Sounds like the hose off but not thare but sounds like pic or some ware about passat back motor area
Old Nov 22, 2019 | 07:31 PM
Shane King's Avatar
Back
Valve cover area or hose backvthare
Old Nov 22, 2019 | 07:33 PM
Shane King's Avatar
Al
Alot of air like air hose off air compressor Amor air loud hissing forme thare
