Interior LED and liscense plate led's?
Where can I buy these guys? Looking to replace all the interior, and liscense plate lights, also under the trunk.
Thanks |
almost any good auto parts store
check this site and see what they can do for you
http://www.hoen-usa.com/ also http://www.beastpower.com/ |
For cabin LEDs you can use any brand, ebay, whatever. Make sure you dont go too cheap, you dont want them staying on when the car is off.
http://www.superbrightleds.com/ Im not sure what the part # is but you want an LED with this little part on it that wont allow it to work with trace amounts of power in the system. Spend $ on good ones for the exterior, cheap ones will trigger warning lights. http://www.hoen-usa.com/licenseplate.htm For trunk lighting and engine there are these guys http://www.hoen-usa.com/exp.htm These match Porsche illuminated sills, if you dont care about matching that you can save $$ and get cheaper LEDs but the color will be less white and more blue white. |
Perfect! Thanks guys
Originally Posted by gmoney
(Post 2557002)
Just one question: any reason you want more lighting on the rear plate?
Too right, Eric! LOL
Originally Posted by Eric (Plug Guy)
(Post 2589411)
I kind of like my plate to look dull and dark.
I'm just sayin' ;) |
(Post 2589516)
Originally Posted by evoviiiyou
(Post 2589985)
So people can clearly read your vanity plate??
(Post 2557002)
http://www.superbrightleds.com/ Im not sure what the part # is but you want an LED with this little part on it that wont allow it to work with trace amounts of power in the system. Spend $ on good ones for the exterior, cheap ones will trigger warning lights. http://www.hoen-usa.com/licenseplate.htm For trunk lighting and engine there are these guys http://www.hoen-usa.com/exp.htm These match Porsche illuminated sills, if you dont care about matching that you can save $$ and get cheaper LEDs but the color will be less white and more blue white. EDIT: also, any other suppliers for license plate lights? HOEN has been "out of stock" for ages. |
interior LED model numbers?
contact Hoen direct for license plate complete modules, they are typically sold before they hit the web but timeframe is a few weeks and typically they dont post the link online, only e-mail direct. I run a set, they are fantastic but indeed quite bright so skip them if your trying to be stealth. Net result is a vast 'modernization' of the car though, I get compliments on them all the time.
Hoen dont recommend interior bulbs, asked but they say the say coldness in side the car is tough on the eyes and to skip it. For those who still want to stick in whiter ones 6411 is the dome and W5W is the courtesty light. |
| All times are GMT -6. The time now is 05:40 AM. |
