Short Shifter, iPod & XM integration installations on 997 Turbo by G Rides
Installed Porsche Short Shifter, perfect factory fit offering about a 30% reduction in shifter throws.
Short Shifter is on the left, overall height is the same but notice the pivot point is higher.
Install almost complete here, there's some gorgeous Carbon Fiber on the E-Brake under that blue tape, got to keep that stuff safe.
iPod integrated to the factory Porsche PCM using this Dension unit.
iPod connects/docks in the ashtray space.
XM integrates to the factory Porsche PCM also, using Porsche components. On the left is the new antenna for the XM & Navigation on the right is the stock antenna for just the Navigation.
Needed to trim one of the tabs of the new antenna so it would fit.
This is where the antenna goes, which is under the cowl which is by the windshield and the wipers.
Here's the new antenna installed in the cowl, a little trimming needed to be done but I kept it clean.
This is where that antenna is, under the cowl just above the cabin filter.
So here's the bonnet without carpet or trim pieces so the wires may be run and the XM and iPod components may be installed. Notice the blue tape on the passenger side above the Amp and Navigation DVD Drive, that's where the components are going.
I prefer not to drill holes in the metal of the car if it can be avoided so I found some grommets to run the wires through and sealed them back up when done.
Here's the bonnet put back together, with this install it still looks stock. That little door to the top passenger side is where the XM & iPod components are.
Here are those components behind that door taking up what was a little cubby space. It was a tight fit but it worked out and still have access to USB ports and controls of the those components when needed. I would have like the wires to be a little neater but those orange wires are fiber optic and can not be trimmed or bent sharply.
iPod Dock.
XM integrated and controlled through PCM.
iPod integrated and also controlled through PCM.
Optional iPod Connection in the Glove Box, just need to change a connection for the iPod cords.
I need to thank Eric over at Bumper Plugs who supplied the Dension and offered awesome Tech Support and Customer Service. I also want to thank this customer for the work, we really appreciate your business.
iPod Dock.
Thank you. I'd have to check to be certain. The XM integration is a Porsche component, just need to see if 07 car is any different pertaining to these components. If it does work, I believe you'd be able to just daisy chain it to your dension and change the satellite antenna.
G Rides did a great job of installing these options on my 08 997TT. The workmanship and care to detail was awesome. Having the iPod integration and the XM radio makes the driving experience even better. The short shifter was a huge improvement. Thanks Gary for a first class job.
insp185 what can I say, thanks for all your continued trust and business, really appreciated.
TT Surgeon it looks like the XM integration should work for you. This one was bought from Sunset Porsche, Part#: 95504490267
Slick and tidy installs! Thanks for documenting the whole process. Bookmarking this one for future reference, should an 07-08 Turbo come my way in 2010. The iPod and XM features would be great additions.
Very nice install. I have an 02 996 TT so do you know if the ipod electronics would work with the stock 02 stereo (OEM Porsche/Becker CDR-220 in dash CD player/radio/stereo unit)?
Also in the market to upgrade the stock 996 shifter, interested in selling the one you removed if it is in good shape? Part number I'm looking for is 997 424 010 00.
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
I'll look around for a shifter for you, will be installing another Short Shifter Next week.
More info here which may help you out xc17pilot: https://www.6speedonline.com/forums/...installed.html
Nice final product, Gary!
And for anyone with Dension questions, email me anytime.
eric@bumperplugs.com
The Gateway 500 unit on our Order page works with MANY makes/models (Porsche, Audi, MB, BWM, Saab, Cooper, and we even did a Rolls not long ago!).
Thanks in advance.
Thanks in advance.
