Sponsored by: Bears Transport
Will VP MS109 make the car run lean if not tuned for it?
  #46
Old 07-28-2010, 12:26 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Mark can better answer this but I don't think it has anything to do with your fuel. The sensors measure how much air flow and send a signal to the injector to deliver X amount of fuel to meet the afr ratio set by the tune. It wouldn't matter if it was ms109, 89 octane, or grappa in your tank.
  #47
Old 07-28-2010, 12:33 AM
bimmer81's Avatar
bimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to beholdbimmer81 is a splendid one to behold
It also seems that you are not holding boost. It decreases as your rpm goes up. Does your car feel slower at the higher rpms?
  #48
Old 07-28-2010, 12:40 AM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
This is an interesting read and I am now more confused.
Quoted from Yellobullets.com
Race Gas Stoich Rating Tuning Considerations
Well I have seen questions from time to time about adding race gas without tuning which can be a very expensive experiment. I am going to explain how stoich effects AFR. Hopefully in simple format.
I am not going to get into MAF transfer functions or other tuning functions.This is just about fuel.
First lets define a few terms:
AFR: Air Fuel Ratio
Stoich Rating: In simple terms is the AFR to have chemically complete combustion that is neither rich or lean. For Example most pump gasoline is about 14.64 to 1. Which means 14.7 parts of air to 1 part of fuel.
Lambda: Is a term that is utilized when tuning. In basic terms think of it as an adjustment to your stoich rating when tuning AFR. For example with pump gas tuning .80 lambda, 14.7 x .80 = 11.76 AFR target.
Lets assume your car blower car has a nice tune that gives a perfect 11.8 AFR under WOT with pump gas.
So now it is race day. We add some timing to our tune, drain the fuel tank, and fill up with some high octane unleaded VP109.
We go for a blast down the 1/4 mile while datalogging and see the A/F is reading 12.8 then make a quick trip to the bathroom only to find out they are out of toilet paper.
There are a few factors here to consider.
The stoich rating of VP109 is 13.41.
Most wideband A/F modules are calibrated to 14.7 pump gas stoich.
So this is the formula to determine the true A/F for the run.
AFR/Wideband Stoich x Race Gas Stoich
12.8/14.7*13.41= 11.7 AFR on Race Gas
So you may think 11.7 sounds safe but we must remember the VP109 stoich is 13.41. So 11.7 AFR = .87 lambda. For the most part a safe lambda value is .80 to .82 for a forced induction mustang. I prefer .80
So we take VP109 stoich of 13.41 x .80 lambda = 10.73 AFR
This is the AFR (10.73) I am tuning for.
Keep in mind this is not what will display on your wide band as it is programmed to 14.7 stoich. You must convert the AFR.
AFR/Race Gas Stoich*Wide Band Stoich
10.73/13.41*14.7 = 11.76 AFR is what I want to see on my wideband when running VP109.
Just to reiterate 11.7 on the AFR display with VP 109 is really a 10.7 AFR.
Ok so hopefully you are not totally confused.
There is a simple solution to all of this madness. The SCT Advantage software has a Scalar for Stoichiometric Air Fuel Ratio. You simply enter the correct value for the fuel you are using and all lambda fuel calculations will be based on this value. Then just do the first formula conversion to determine what you should be reading on the AFR display. Some AFR modules may be able to be programed to the correct stoich.
Or leave the stoich in the tune and wideband at 14.64 and calcualte what AFR you need to read on the wideband for the fuel that is used. (This is how I did it in the past, but I find it easier to change the stoich scalar)
This is why you have to exercise caution when mixing race gas and pump gas as you do not know the true stoich of the mixture. The leaded race fuels have a stoich that is closest to pump gas. I always drain my tank before putting in the race gas. When I mixed fuels in the past I didn't notice a drastic change in AFR, but when I have 100% unleaded race gas it really leans out with a 14.64 stoich scalar in the tune.
The other caution is the winter (oxgenated) gas we get in Arizona. I noticed the car leaned out in the winter when it was tuned on the better summer blend. A 14.1 stoich scalar works for the AZ winter gas if your initial tune was based on the summer blend.
Race Gas Stoich Ratings
Sunoco MO2X UL – 14.5
Sunoco 260 GTX – 14.4
Sunoco 260 GT – 13.9
Sunoco 260 GT Plus – 13.7
Sunoco Standard – 14.8
Sunoco Supreme – 14.9
Sunoco MO2X – 14.5
Sunoco HCR Plus – 14.8
Sunoco Maximal – 15.0
Sunoco MaxNOS – 14.9
Turbo Blue Unleaded (100 octane) -13.9
Turbo Blue Unleaded Plus (104 octane) - 13.7
Turbo Blue 110 - 14.7
Turbo Blue Advantage - 14.9
Turbo Blue Extreme - 15.0
VP Street Blaze 100 - 14.16
VP C10 -14.53
VP C16 - 14.77
VP 110 - 15.09
VP MS109 - 13.41
<!-- / message -->
  #49
Old 07-28-2010, 12:43 AM
Abby997TT's Avatar
The car feels faster in every rev range than pump gas. I think the car suppose to reduce the boost at higher rpm.
  #50
Old 07-28-2010, 12:46 AM
Abby997TT's Avatar
The car is definately running lean, and that's probably why it feels faster than pump gas.
If other fvd flash users can log theirs that will be perfect!
  #51
Old 07-28-2010, 01:00 AM
I would start with the has your supposed to run. Run the same 3rd gear. But get on it at 2k to redline. Try 6700. Not sure what ur cut off is.
Also. Let us know what the temps are outside that day.
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
  #52
Old 07-28-2010, 01:12 AM
Abby997TT's Avatar
Thanks!
I will get that tomorrow night.
Just a quick question. Am I putting my motor in serious danger by running at this lean of afr?
  #53
TTdude's Avatar
Don't mean to add to the confusion but this is what Markski was referring to when he said your car would run lean and I said I didn't think it would make much difference if you substitute one oxygenated fuel (ethanol) for another (mtbe). Since the SR for ms109 is 13.4 and your 94 pump fuel is assumed to be 14.7, then a .80 lamba reading on pump would correspond to a 14.7/13.4*.80=0.87 lambda on ms109. Since you are mostly on pump, you still seem to be running lean. If you were running straight ms109 then your lambdas would be looking much better.
I still think you should get a Pbox so you can quantitate speed rather than by feel.
  #54
Old 07-28-2010, 01:25 AM
Abby997TT's Avatar
Does that mean I am actually running leaner than the numbers are showing?
where can i buy a vbox?
  #55
Old 07-28-2010, 01:29 AM
Well if you been running like this for a while you probably would have hurt it long time ago.
Run that ms109 out of it. Put some fresh pump gas. Her on it a few times so the ecu adapts. Run it. Send the logs to your tuner. A good tuner will be able to address the issues if any exist.
9.66
click to view
  #56
Old 07-28-2010, 01:36 AM
Abby997TT's Avatar
I used roughly 10 gallons ms109 mixed with 10 gallons of pump fuel.
I have had the fvd tune for about 1000 miles if not less.
  #57
Old 07-28-2010, 01:41 AM
TTdude's Avatar
Not necessarily. I don't really know what the stochiometric ratio of your pump fuel is and I don't know if ms109 is really 13.4. You should confirm with VP, maybe it's on their website. Since you are running mostly pump, the actual lamba is probably fairly close to the gauge reading. And boost is determined by load, not RPM. Your datalog will show this. Boost will drop accordingly as you pick up speed and your load goes down.
I bought my Pbox from Dan at Vivid. Good service and price (even though I seem to get under his skin sometimes ).
  #58
Old 07-28-2010, 01:48 AM
Abby997TT's Avatar
Cool Thanks! I will pick one up hopefully by next week.
  #59
Old 07-28-2010, 02:00 AM
TTdude's Avatar
Yes, Markski makes a lot of sense in that you need to talk toyour tuner and get some real feedback from those who do this for a living. I think your numbers look like they are within the ballpark, especially considering that you're not running a whole lot of timing. You're not going to find one tuner overly criticizing another tuner's data in public.
  #60
Old 07-28-2010, 02:09 AM
Abby997TT's Avatar
Yes, I think the best is talk to fvd and see what they say or correct. I will call them up first thing tomorrow morning. I will do some more logging tomorrow night to see the pump gas i put in the car made any difference. I really don't need a 30k repair bill for a new motor at the moment. :-(
Quick Reply: Will VP MS109 make the car run lean if not tuned for it?
