997TT tuning; INTERCOOLERS ?
Old Aug 19, 2010 | 12:57 PM
most aftermarket direct replacement cores are 3.5" tall. then the 4.5s", 5"s, and 6".
Stock is about 2.5"+. but its also tube and fin vs. bar & plate. Also look at the amount of plates in a core across.. some have only 11.... some 13.. and the $15K ones have 15 or even 16. that all matters... as well as the design of the core.. the cheaper end Asian ones have def. a less compacted design if you look thru the core... not to mention the end tanks... thats another story... you want the core to get air across the compete core not just the center... thus the end tank design does matter.... etc etc... bottom line is most of the vendors here sell really good products... each with some diff. approaches...
this is mine... 3.5s and 4.5s....
Uploaded with ImageShack.us
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Aug 19, 2010 | 02:40 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Originally Posted by jiaim
le mieux est de choisir les fvd 5" qui sont fabriqués par TPC, au moins FVD pourra mettre à jour ton ecu avec les caractéristiques exactes correspondant à ces intercoolers.
http://www.fvd.de/de/fr/Porsche-0/-/...rbo---GT2.html
Le mapping sera refait sur banc et non pas un ECU générique acheté tout fait (pas plus à un autre qu'à FVD d'ailleurs), donc pas d'obligation, mais merci de ta bonne intention.
Old Aug 19, 2010 | 10:01 PM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
Alright, enough of the french please.
Old Aug 20, 2010 | 02:10 AM
speed21's Avatar
Dont you speak french ruf? I know some words but i think they are all rude .
Old Aug 20, 2010 | 03:35 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
TPC has one of the best I/Cs out there
Old Aug 20, 2010 | 08:46 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Product quality offered by Mark is awesome...Years ago,he was the first to get to 9s...show us some more photos mark...Are 4,5inch ics necessary for stock VTgs?or 3,5 would be fine?
Old Aug 20, 2010 | 10:06 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
I think Markski would agree with me.....if you're still running stock VTG's, or even upgraded VTG's, you will be fine with the 3.5" cores. When you're still using VTG's, the size of the core is not as important as it's efficiency. Bigger isn't always necessarily better. In order for a larger core to become efficient, you'll need to be pushing an ENORMOUS amount of air through (from a non-VTG turbocharger for example), much more then most modified VTG's are capable of.
Old Aug 20, 2010 | 10:48 AM
Most tuned 997s do run a decent amount of boost... thus smaller turbos produce more heat then bigger turbos at the same boost level.... the smaller ones work harder ... produce more heat...
I found that our 4.5s work 12 degrees Celsius( on average) better over our 3.5s... I also found that its very hard to simulate the efficiency of a IC just by a dyno run... a 0 to 150mph for example showed me different results....
I also noticed that some discuss only the hight of the ICs... although there are pluses and minus to both.. the width as well as the amount of bars does matter too....
All in all the 3.5s available my most tuners are good quality... there are some differences between them ... like ease of install, price, what's included in the kit... etc etc...
Just generalizing.... not making any claims that one is better over the other...
9.66
click to view
Old Aug 20, 2010 | 11:00 AM
ruf_turbo's Avatar
I don't know any words but I do know some gestures.
Er, on second thought, maybe it's Italian that I know.
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
TrackOne
Aug 20, 2015 12:56 PM
