997tt brakes look wavy
Old Sep 9, 2010 | 12:22 PM
spooling's Avatar
spooling is infamous around these parts
my rear brake rotors on my 997.1 turbo are looking a little bit wavy. A friend of mine says this is normal for my car but i am not sure? The car has 11k miles on it. when my brakes are worn will the cpu give me a warning? my brakes are oem steel ones not pccbs.
Old Sep 9, 2010 | 07:22 PM
PSTT07's Avatar
PSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nicePSTT07 is just really nice
I have a 07 with 14k miles and have the same look on the rear rotors. My vehicle goes to the dealer for regular scheduled maintenance and they have never mentioned anything out of the ordinary. Last oil change they provided a list of things inspected and the brakes/rotors was on there with no call for action. I don't track my car and tend to take it easy on the brakes as I don't enjoy the excessive brake dust they are notorious for. That being said, I'm sure I'll have to replace the rotors and the pads when the time comes so everything wears as it should.
Old Sep 9, 2010 | 07:59 PM
spooling's Avatar
Alright thanks for the imput I guess I won't worry. Do you get squeaks at all? These brakes feel really wooly and almost weak compared to the ones on my c63
Old Sep 9, 2010 | 08:07 PM
PSTT07's Avatar
They don't squeek fortunately. I've always been very happy with the feel for the type of driving I do.
I've come accross some threads on here that discuss brake pad options. I'll probably go with the OEM pads when the time comes but you could look into other vendors for added feel/grip.
Old Sep 9, 2010 | 08:17 PM
spooling's Avatar
Will the car warn me when the pads are on there way out?
Old Sep 9, 2010 | 08:43 PM
E55AMG's Avatar
E55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud ofE55AMG has much to be proud of
Really?? Wow, i've had an '06 997S and now my turbo and compared to the brakes on the E55 I had there is no comparison between the brakes on the porsche's and the Benz.
Old Sep 9, 2010 | 09:16 PM
PSTT07's Avatar
I don't know if there is a pad-wear indicator system. I would ask the technicians to check it out wherever you have your car serviced. I know my $$$ oil service includes a thorough check. Not happy with the high price but appriciate certified techs working on the vehicle. Last time at the dealer I received a service checklist detailing two pages of items inspected, and the brakes were included.
Old Sep 9, 2010 | 09:21 PM
PyroKerry's Avatar
PyroKerry has a spectacular aura aboutPyroKerry has a spectacular aura about
Yes, you will have a warning light on the dash when the pads get too thin. There's a little temperature sensor that slides into a hole drilled in the pads. When the pad gets thin, the sensor gets hot, and the warning light comes on!
The wavy surface on the rotors is fairly common, and it doesn't cause any problems.
Old Sep 10, 2010 | 12:06 AM
raiyu's Avatar
raiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to beholdraiyu is a splendid one to behold
You can also do a quick visual inspection of the pads, when the pad width is close to or smaller than the width of the backing plate its time to replace them soon.
If you are doing track time you def need to replace at this point as the pads will have a harder time dissipating heat as their width decreases past a certain threshold, so when you get to around 50% its time to consider a replacement or at least grabbing an extra set to the to track with you.
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
