Help needed log file to be sent to swtizer
Old Apr 2, 2011 | 07:36 AM
Oman911Turbo75's Avatar
Oman911Turbo75 is infamous around these parts
Hi guys
I need help to send Durametric 6 Data log file to switzer, i installed stage 2 680hp " 2009 997tt tip" and i experienced boost loose starting at third gear with tune was 95oct feeling the RPM kinda slow at third and fourth gear i donnt know if its fuel or hose leak, later switzer sent me the 91oct tune same problem
tonight i will reuse more race fuel check if the problem is gone
Tomorrow i will check the hoses if there is leak
i raced my brother 997turbo s pdk from roll my car is head first and 2nd im ahead once my car shifts third it gets slower drops from 1.2+ till 0.8 and 0.6 sometimes
The help i need now is that swizter asked me for
RPM
Throttle Position
Lambda 1 actual value
Ignition advance
Boost pressure
I sat yesterday with Duramatric 6 at actual values to find those words i couldn't find them or to know them since English is my second language, please which to pick from actual values for the five things so i can send the data-log please
Old Apr 2, 2011 | 03:56 PM
Update
I put about 2 to 3 liters of racing fuel, raced 997turbo S from i gave him 2 cars and at higher speed i keep going more, but still third , fourth and fifth gear some little hesitation , first and second gear super fast...
Old Apr 2, 2011 | 10:01 PM
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
Oman911 when was the last time you changed the ignition coils and spark plugs?
Old Apr 3, 2011 | 01:31 AM
i changed the spark plugs only when i bought the kit from switzer, plus when they change the spark plugs they must seen the ignition coil remember my car has 7000KM only
VGLNTE1
Aug 24, 2015 12:23 PM
00aston
Aug 24, 2015 09:29 AM
Fadi
Aug 21, 2015 03:43 AM
