Washing your car and getting the engine, airbox and blower wet
Heavy rain and washing cause my belts/belt to squeal. Some of my symptoms are, error msg regarding batt chg once, and slight loss of power steering until the belt stops slipping on the pulley. I just rev it a bit until the belts/belt stop squeaking. I can't imagine some water getting into the engine compartment will damage the car.....right?
Ken
Ken
You do that.
http://www.youtube.com/watch?v=zh9c_V9ocyg
I am on my third turbo in 12 years , wash it and never had a single problem. Never had the idea to use a towel on the engine... And most of these years I was driving in Germany where it rains quite a lot.
[quote=floridaBMW;3193474]Heavy rain and washing cause my belts/belt to squeal. Some of my symptoms are, error msg regarding batt chg once, and slight loss of power steering until the belt stops slipping on the pulley. I just rev it a bit until the belts/belt stop squeaking. I can't imagine some water getting into the engine compartment will damage the car.....right?
Can contribute to a belt that never stops squealling (washes out additives used in drive belts to soften belt against squealling) or a mass sensor that goes bad ($+$1000 to repair mine) or a power steering bearing going to pot. Stuff like that. I got tire of a squeaking belt and found a solution.
That's pure luck....even the dealerships know that water in the engine compartment is not the best situation for any engine and causes the well-covered up "factory squeal.".
I dunno... I live in Seattle and when I drive my car to work, it rains on it all day long. Never heard anything... never thought to cover it up.
I just figured they must have thought of this issue...
Im with you Doc. Putting mats and things to cover up on the outside is a little pedantic. Some of you guys need to stop worrying so much about a little bit of water and spend more time driving the pants of the thing.
Trust me, I don't want to worry about it. But after the wash, my check engine light came on. The car ran beautifully so I figured it was something to do with the engine compartment getting wet. I let it dry, turned it on--CEL still came on. I read on this forum and others that if you disconnect and reconnect the neg terminal of the battery for a few seconds, it will clear the CEL light. I did it and sure enough, no more CEL. I presume that if it was a chronic emissions issue (or something important), the CEL would go back on. Since it didn't, I can only assume it was related to the water. If it doesn't hurt the car, I don't give a s--t if there's an ocean of water in there--fish are ok too! But rest assured speed21, that I am spending less time worrying and more time enjoying
I dont go crazy with the hose in the slat area anyway and usually hose just a little sideways against the grain of the slats and never directly inside the slats. Spraying directly toward the slat openings may possibly overload the draining system but looking at the inside of the lid it looks pretty well sorted out. Its hard to say what the cel was all about if the engine was running sweet. Did you note the code at all?
Great to hear it MK23! Thats the way it should be!
Beides isn't this in part what this Forum is all about, to help others avoid expensive repair bills at Porsche. Or is the Forum just for happy face stuff like car photos, what tires, whether to flash, exhaust sound etc.
What is needed here is a prayer to the Rain-god to provide you a drowned mass air sensor and a drive-belt that will not stop squeaking to help remove from your thought process any evil associated with being "a little pedantic.
I think what u've posted up until here was worth reading....
Ken
Ken
It is interesting. We get the squealing belts after a wash, but never when driving in the rain, and it does rain hard here.
Maybe it's more wash water from the bottom that gets the belt wet while the engine is off that causes the issue ?
--CC
--CC
Sorry guys to bring this ...back from the dead
Direct quote from 997 GT2 Owners/Driver's Manual.
"Cleaning and preserving the engine compartment"
"The engine compartment and its surface are treated with a corrosion inhibitor at the factory".
"If grease solvents are used to clean the engine compartment, or the engine is washed down, the process almost invariably removes the corrosion inhibiting coating. It is therefore absolutely necessary to have durable preservative applied to all surfaces, body seams, joints, and assemblies in the engine compartment".
Am I missing something here, or this quote by the manufacturer (Porsche AG), makes perfect sense, i.e. NO problem to be expected from washing and using shampoos, water etc. to clean engine bay.
