Sponsored by: Bears Transport
boost on 997.1
Old 06-01-2011, 05:01 PM
topspeedua's Avatar
topspeedua is on a distinguished road
boost on 997.1
Hello. Can anyone tell me what is the boost increase on tuned 997.1? stock boost is 14.5. what numbers you see on a tuned ones? on stock turbos? 20 psi?
Old 06-01-2011, 07:12 PM
gmoney's Avatar
More in the 17 range if you believe the factory gauge
Old 06-02-2011, 09:58 AM
topspeedua's Avatar
there are a reason not to believe it? in regular mode i have 14 psi. in sport mode I have 17lbs. when car is reflashed what boost should I see?
Old 06-02-2011, 10:06 AM
jhbrennan's Avatar
Many of the tunes I've seen just turn on the Sport Chrono overboost function so it's overboost all the time so 17 psi all the time. I'm sure there are other tunes that take boost a little higher.
Old 06-02-2011, 10:11 AM
topspeedua's Avatar
So all the decat+tune are 17psi?? what power can be expected from decat+tune?
Old 06-02-2011, 10:27 AM
gmoney's Avatar
on 91 octane about 70-80 hp with full exhaust + tune.
Old 06-02-2011, 10:43 AM
topspeedua's Avatar
Is it the same with stock exhaust and cats taken off?
Old 01-12-2018, 08:12 PM
Dan997t's Avatar
Dan997t is an unknown quantity at this point
20# psi with tune
I have a mild ecu tune and was hitting 20# every day. Only other mod is Fabsport exhaust. Tuner says 600hp.However, it’s having an issue now where it won’t make over 15#. You can feel the ECU is holding it back. Suspect bad gas...
Old 01-13-2018, 03:27 AM
turbofan997's Avatar
turbofan997 is an unknown quantity at this point
The dashbord only will show a max of 1.2 bar even if you run with 1.4,
The only way to know the exact value is to check with a piwis tester ( max value showed 1.5 bar) or to connect a pressure sensor directly to the pressure line or a cobb accessport can show it.
Old 01-13-2018, 05:03 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Right,
And to answer the question when tuned for pumpgas boost is about 1,25/30Bar 18/19psi.
YJosephTT
03-28-2016 02:31 PM
Greehn
09-16-2015 04:45 PM
proTUNING Freaks
09-15-2015 07:28 AM
johnny.dangerous
09-11-2015 02:39 PM
rsdub
09-10-2015 03:30 PM
Quick Reply: boost on 997.1
