Ouch! That's Racing....
Yesterday, in 101 degree heat, as I was trying to "win" my first DE by driving Flat Out (just kidding) I was accelerating onto the long straightaway at about 100mph, when I felt what seemed to be a misfire.........Oh, if it were only that simple.
Looking in my mirrors, there was a large cloud of white smoke so I got off the racing line, put it in neutral and coasted to a safe stop. The fire crew was there in a heartbeat and took control. No fluids on the track, car idled fine but there was this problem of the smoke.........oh, yes. and the 5 foot flame from the exhaust that the onlookers said was really impressive!! Call the flatbed and take it to Denver. Diagnosis this AM is a blown (disintegrated) turbo with the other not far behind, munched intercooler, shot exhaust system, etc. etc. $10,000 ++ repair bill. Good news, if you can call it that, is I'll end up with bigger turbos, better intercoolers and a fabspeed exhaust - none of which were in the plan but are now. The slippery slope now owns me!! So what part of racing Porsche's...........:rolleyes: |
Ouch indeed!
Good thing there's a silver lining! |
Aw crap! Any of these aftermarket bits or OEM? Any idea what caused it?
Originally Posted by bonehead
(Post 3263006)
Ew that's bad news, sorry man. Is ur car warranty in play here or are u writing that off due to tune and DE event?
Ken |
Originally Posted by Steamboat
(Post 3262976)
Looking in my mirrors, there was a large cloud of white smoke so I got off the racing line, put it in neutral and coasted to a safe stop. The fire crew was there in a heartbeat and took control. No fluids on the track, car idled fine but there was this problem of the smoke.........oh, yes. and the 5 foot flame from the exhaust that the onlookers said was really impressive!! Call the flatbed and take it to Denver. Diagnosis this AM is a blown (disintegrated) turbo with the other not far behind, munched intercooler, shot exhaust system, etc. etc. $10,000 ++ repair bill. Good news, if you can call it that, is I'll end up with bigger turbos, better intercoolers and a fabspeed exhaust - none of which were in the plan but are now. The slippery slope now owns me!! So what part of racing Porsche's...........:rolleyes: thanks, |
Would love to find out exactly what went wrong. Im wondering if you ran a high flow exhaust vs. the stock exhaust if it would have helped? With being flashed and all which would add some stress to the stock converters especially.
I think it is very important for us as a community to figure out what led to this failure. From your post and sig line I would gather:
1) you are at high altitude - less density for the intake charge 2) in the Colorado area you get 91 octane max 3) you have a 997.1 GT1 motor 4) you have an ECU flash 5) you were running a stock exhaust 6) this happened under high load - accelerating and high atmospheric temps My guess would be heat related failure of the turbo - flashing the ECU without reducing exhaust backpressure is a risk I did not want to take. The flashed ECU's allow more boost and thus will generate more heat and higher EGT's. The VTG turbos are fragile when it comes to high EGT's and the stock ECU is designed to pull boost when the EGT's get too high. A modded ECU may not be so stingy with the boost when the EGT's climb. Reduced backpressure from an aftermarket exhaust has been shown to reduce EGT considerably. Things I'd like to find out: 1)how many miles on your turbo? 2)what kind of oil you were running? 3)what kind of fuel and any additives (octane boost)? 4)did you notice any higher temps on your oil or water gauges? 5)was the car running any different prior to failure? 6)what elevation were you at? |
Originally Posted by eclou
(Post 3263249)
I was toying with the idea of a flash, but now I'm extra scared 0_0; |
Dont be too concerned with the flash + exhaust, there are probably more Turbos running around with this setup than stock ones.
(Post 3263249)
1) you are at high altitude - less density for the intake charge 2) in the Colorado area you get 91 octane max 3) you have a 997.1 GT1 motor 4) you have an ECU flash 5) you were running a stock exhaust 6) this happened under high load - accelerating and high atmospheric temps My guess would be heat related failure of the turbo - flashing the ECU without reducing exhaust backpressure is a risk I did not want to take. The flashed ECU's allow more boost and thus will generate more heat and higher EGT's. The VTG turbos are fragile when it comes to high EGT's and the stock ECU is designed to pull boost when the EGT's get too high. A modded ECU may not be so stingy with the boost when the EGT's climb. Reduced backpressure from an aftermarket exhaust has been shown to reduce EGT considerably. Things I'd like to find out: 1)how many miles on your turbo? 2)what kind of oil you were running? 3)what kind of fuel and any additives (octane boost)? 4)did you notice any higher temps on your oil or water gauges? 5)was the car running any different prior to failure? 6)what elevation were you at? A "blown" turbocharger isn't really a diagnosis...it is a symptom. Was the turbo mechanically faulty or were there factors that lead to its failure. Did you have any datalogs of EGT, lambda, IAT and timing after flashing your ECU? Often times we (as consumers) purchase a flash for our car, impressed with the overall improvement on the street and the incredible dyno curve that the tuner publishes...but what happens to the ECU management lap after lap in high temperatures is another question. Were safety measures turned off on your tune? Was your ECU pulling timing or changing AFR to compensate for higher temperatures? |
Originally Posted by floridaBMW
(Post 3263095)
Ken |
(Post 3263249)
:rolleyes:hate when that happens
Originally Posted by bbywu
(Post 3263350)
This is an excellent review and you are asking questions that I would also be asking before spending significant $$$ in aftermarket parts. Turbo failure is not very common, and it's probably important finding out why this problem happened.
| All times are GMT -6. The time now is 06:02 PM. |
