Dash squeak sorted!!!
Old Jul 30, 2011 | 03:00 PM
mm450exc's Avatar
mm450exc is infamous around these parts
So what looked to be a squeak from the dash came from a screw/plastic/metal clip that holds the plastic inside the wheel arch (lower front part of the wheel arch). Pulled the light and pressed on the plastic behind it (basically the outside of the wheel arch) - squeak squeak squeak!
The dealer found it but wanted the car for a few days to track it down. So I sorted it. Just put some grease on the section which was the problem.
The lower arch is held by 8 screws. You just need to turn the wheel to one side depending on what arch you are working on. No need to pull the wheel.
That squeak almost drove me nuts!
Old Aug 7, 2011 | 01:20 PM
mm450exc's Avatar
Started squeaking again! So found the problem now I think. 2 loose screws.
adnanm3
Oct 25, 2016 08:38 AM
ECS Tuning - BMW
Oct 1, 2015 01:35 PM
ECS Tuning - BMW
Oct 1, 2015 01:29 PM
