Sponsored by: Bears Transport
Modded GT2 Vtgs vs Modded 997tt Vtgs...Result inside
Old 02-26-2012, 08:53 AM
MannschaftQ8's Avatar
MannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the rough
Since it is my first thread here. I hope it will be good info for u guys.
Cars: Both cars has tip tranny.
Mods: Both cars has same 700/750hp kit ( one has modded gt2 and the other one has modded oem vtgs *( bigger comp wheels, clipped turbine and extrude housing ).
Result: We did several rans and got same results. Rolling from 80kmh to 300kmh both rans neck2neck.
I know some guys think to get those damn expensive gt2 turbos but as u see it is not worth it IMO!
Old 02-26-2012, 09:19 AM
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
That isn't a big surprice because the biggest difference between turbo's and GT2's turbocharger is the compressor. If both have similar modded compressors and tune the results should be the same.
Differences in turbine side are (according to the info I've gathered) 15 deg clip on GT2's wheel and housing area. 4.05 cm2 vs. 4.26 cm2.
Old 02-26-2012, 09:40 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Thanks for sharing I think it's handy to know that!!!
Old 02-26-2012, 10:00 AM
topspeedua's Avatar
topspeedua is on a distinguished road
where did the weight difference go in your runs?
Old 02-26-2012, 10:39 AM
cayenne_ksa's Avatar
cayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond reputecayenne_ksa has a reputation beyond repute
was the stock turbo VTG modified to match GT2 spec ?
Old 02-26-2012, 11:20 AM
MKS's Avatar
MKS
MKS is offline
MKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of lightMKS is a glorious beacon of light
Im guessing both cars were 997 turbos ... Nice runs and tests guys
Old 02-26-2012, 12:42 PM
I don't think it is specifically modified to match gt2 spec but they flow same as gt2 turbos
Old 02-26-2012, 12:43 PM
Thanks bro
Old 02-27-2012, 01:46 PM
997John's Avatar
997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all997John is a name known to all
Good info, thank you.
From dig start the GT2 turbos are lage.
Old 02-27-2012, 08:52 PM
uaeturbo's Avatar
uaeturbo has a spectacular aura aboutuaeturbo has a spectacular aura about
Good info
Old 02-28-2012, 12:06 AM
You welcome guys
Old 02-28-2012, 02:51 AM
GT-TT's Avatar
GT-TT will become famous soon enoughGT-TT will become famous soon enough
Tried same experiment on my car with optimised tunes for both setups. The modded GT2 VTGs made around 20-25hp more than modded TT ones on same dyno. The larger housings of the GT2 units make for better flow and IAT on higher gear accelerations. IAT also stay lower because of same reason. However you do get a bit more lag because of the above.
Unless you specify with the ECU the new parameters (torque targets etc) there would not be a substantial power difference between the 2. But if you do then there will be.
Old 02-28-2012, 03:50 AM
Did u have extrude housing + clipped turbine on the 997 modded vtgs or upgraded comp wheels only?
Old 02-28-2012, 03:55 AM
GT-TT's Avatar
both were optimised by same tuner. clipped turbine, cut back etc.
Not sure what you mean by extrude housing on the tt ones? The housings of the GT2 are quite a bit bigger, not sure if its possible to retrofit housings.
Old 02-28-2012, 04:15 AM
World quickest/fastest VTG's in 1/4 mile + 60-130 times has extrude housing.
Quick Reply: Modded GT2 Vtgs vs Modded 997tt Vtgs...Result inside
