How to Install or Remove 997 Turbo Hydraulic Spoiler
Looking to install a new spoiler in replace of your factory 997 turbo spoiler. Here are some instructions. All you need is a new Agency Power carbon GT2 spoiler and a Porsche OEM wing key or as pictured, home made pic. Our contribution
1. Make sure that the Spoiler is in the fully extended position with the help of your spoiler deployment button on the center console.
2. Locate the keyhole in the spoiler rods and the stock spoiler comes off lefty loosey you will need to have some type of spanner wrench like the one in the photo this is one that one of our technicians has made for this project but anything similar that you can get in there that fits the keyhole and wont damage anything will work fine.
3. This would be a good place to have another person in order to make sure you don’t damage the car or the spoiler while installing. Remove old spoiler using the the spanner wrench tool and install new spoiler using the righty tightey method(technical term) make sure the spoiler is on snug. You can start the spoiler on the bolt end that are attached to the spoiler rods by hand then snug them up with the spanner wrench. You don’t want this baby to come off when you’re at Mach 1 down the 101.
4. Enjoy your GT2 Style full Carbon Spoiler it will function just like your stock spoiler but more awesome and stylish. To complete that 997 project look check out the Agency Power Performance parts lineup for the 997.
and a Photo of what it looks like when painted leaving just the last edge of Carbon Visible.
Nice post Dan.
I would also add the following:
1. Painters tape to lower deck as even a taped up spanner can scuff the rear deck.
2. Using multiple pillows to force the hydraulic wing upward a few centimeters - Porsche's service manual actually identifies an inflatable balloon to push the wing upward - the same can be accomplished by stuffing pillows under the blade.
3. You can use the same spanner on the 996TT as well as on the 997TT, however, the tool that Porsche recommends is made by Hazet. The attachment is >$80, and the rod that it connects to is another $100. The advantage is that the Hazet tool is very wide, and will not scuff, mar, or crush the polished cylinder as you tighten or loosen the wing.
https://www.6speedonline.com/forums/...ml#post2994891
I bought the tool in the above link from zdmak - forget the 100plus dollars for the hazett, the sub-20 dollar part from zdmak has a nice rubber coating so it doesn't scratch, and it works great!
Question for anyone about the holes in the cylinders where the removal tool pops in to turn the cylinder for removal or installation: it seems that there is an outer collar and an inner sleeve. When the car had the stock spoiler initially you couldn't see inside the cylinder until you had rotated it and then the tool "popped" in and the whole thing could be loosened. Presumably the reason for the collar rotation was to prevent ants or mosquitoes from going in but I'm trying to figure out HOW to rotate the outer sleeve in order to block off the holes. Right now they are open where the tool fits in in order to turn it. Hope that makes sense. Any help/thoughts appreciated.
3 ways to rotate the outer collar - either by hand (very tight) or insert the tool partially so the pin doesn't go through both collars...just the outer one.
Easiest way is to use a rubber band opener:
Although, honestly, I don't think it's such a big deal to leave the hole exposed.
I'd recommend professional installation of these. I did one of these on our Pure Orange 997 and it was a real PITA!
Really? I've changed it several times with no difficulty. Didn't even need the pillows etc...
Install Help
I'm waiting for a type II wing to come in, and I will be replacing the OEM wing when it does. Unfortunately the pictures with the install help are not showing up. Is there any way those photos can be reuploaded?
PelicanParts.com
997 Vendor Classifieds
08-20-2015 02:39 PM
PelicanParts.com
997 Turbo Vendor Classifieds
08-20-2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
08-20-2015 02:37 PM
PelicanParts.com
08-18-2015 03:41 PM
