Engine starts without brake pedal push
I have noticed recently that I can startup engine without pushing the brake pedal. For some reason the safety feature that required to depress pedal while cranking at Tip cars, is no longer there.
Dealer scanned for errors and found all normal, the brake pedal switch activates brake lights and everything else looks normal. I believe this safety feature is programmed in DME but has been erased/deactivated on mine.
Any thoughts how to activated it again???
Thanks+Regards
Thanks+Regards
did u find a solution for the problem? Coz I'm having the same. Tx
did u find a solution, coz I am facing the same issue.
Regards
Thanks+Regards
Thanks+Regards
Good luck,
DC
Good luck,
DC
thats ideal, why would you want to have to press the brake to start it? Plenty of situations that you might need to spin it over without being on the brakes.
stupid little 250$ switch in my vanquish that went bad and keeps it from going out of N into Gear unless foot is on brake. thought my gearbox went when it was just al little pressure switch........
Yes...This is very simple. You can code that in or out with a Durametric Pro or PIWIS. There is nothing wrong with your car...the setting has just been changed. I did this to mine as I prefer not to have to use the brake when starting it from outside when I am working on it.
Good luck,
DC
Good luck,
DC
We tried at service still same this settings in which brain?
Jul 29, 2019 11:13 AM
Oct 6, 2015 03:43 PM
ECS Tuning - VW
Aug 20, 2015 03:07 PM
