-   997 Turbo / GT2 (https://www.6speedonline.com/forums/997-turbo-gt2-58/)
-   -   18's anyone? (https://www.6speedonline.com/forums/997-turbo-gt2/296005-18s-anyone.html)
kosmo69 Dec 28, 2012 10:24 AM
18's anyone?
Has anyone put on 18s?
I'm thinking about going to an 18in wheel/tire set up. There are plenty of wheel choices, however tires are a different story.
The challenging part is finding the right height combo as not to trip any ECUs.
Let me explain. The stock set up is:
F- 235/35/19 = 25.48"
R- 305/30/19 = 26.20"
Difference of 0.72" taller in the REAR
18" Option A:
F- 245/40/18 = 25.72"
R- 315/35/18 = 26.68"
Difference of 0.96" taller in the REAR
So option A yields a .24" taller rear. Will this trip the ECU/traction control on our AWD cars?
BaldBag Dec 28, 2012 01:16 PM
305/35/18 rear I run and IIRC the Fronts are 245/40/18
Keep it around .7 front to back
TT Surgeon Dec 28, 2012 02:46 PM
I would only run 18s in track or snow tires, be sure there is <2% difference in dia or the diff is a gonner.
johnww Dec 28, 2012 09:27 PM
18" Option A:
With my earlier M3, I went to 19 from 18 and ride was much too stiff. So for this reason, thought 18s for my turbo would give same result. However, 3 tire/wheel dealers all said that Porsche suspension was set up for 19s (excluding snow tires) and consequently ride would be same except for more side-to-side in sharp curves. Also the look changed. A couple 6speeds have posted photos of 997s with 18s and I liked the 19" look much better.
911turbo X Dec 29, 2012 10:19 AM
just installed my 18" today to try it next weekend's track day .. i went with pirielli trofeo 295/30/18 and 235/40/18 .. but when i took the car for a test drive today , there was a problem with ABS ... my tuner said it just needs remapping in the software and everything would be normal then ....
would remapping solve this problem ? :confused:
kosmo69 Dec 30, 2012 08:16 AM
this is good to know. However looking at my the calculations, your set up is:
235/40/18 = 25.40 in
295/30/18 = 24.97 in
difference = 0.43 in SHORTER Rears.
was there any reason you went w/ 30 series, vs 35series on the rears as the 35's would have yielded a stock difference of approx 0.73 in TALLER ?
tks
911turbo X Dec 30, 2012 10:25 AM
tks
thank you for the information ...
30 series was the only available option from pirielli trofeo for the 18" , i know i did a mistake and i've should have bought toyos r888 instead as they offer a 35 series in their 18" range . any way , my tuner said the problem cannot be solved by doing a remap for the software.
kosmo69 Dec 31, 2012 06:05 AM
according to tirerack.com that size combo isnt available. are you running different brand/models f/r?
911turbo X Dec 31, 2012 09:23 AM
im running TROFEO for the rear and TROFEO R for the front.
any way i decided to stay with the 19" wheels, as the 18" plans did not go well after all . BTW im going to sell the trofeo tires i hvae now in 18" , i have 2 sets of 235/40/18 trofeo r and 295/30/18 trofeo , one set was used for few hours and the other set is still brand new .... if anyone is interested let me know..
kosmo69 Dec 31, 2012 09:57 AM
take'em to the next track day event. They will sell.
