997TT MK.1 PCM 3 conversion DONE :)
#516
I have a question to you guys that did the conversion.
1. Is there a possibility to code that i do not have to confirm the porsche info when hitting map or navi (The info text blabla)
2. Is there a possibility to get the fuel consumption, time since i start the car, km and other data to the info page 2?
I mean this:
I only have the information in the dashboard, but not in the pcm3, like the pcm2.1 had. (And the ride time, etc. are only in the pcm available)
I mean this:
#517
I know what you mean with your first question - it would be nice if there was a way of stopping that appearing every time - I don't know of one, but someone may - although it may be a mandatory gov enforced safety feature!
#522
this should work. I think problem in incorrect options coding like engine type etc. piwis II is really weird thing. try to check every setting in all car units to be correct, then try automatic coding of whole car. better find piwis I.
#523
Piwis 1 is impossible to get.
Even in at porsche they use Piwis2.
Porsche coded the gateway from my car after i failed coding it with piwis2.
After i tried coding i didnt have anything working in the car, even the cluster was dark.
I checked the settings under pcm, and there is 997 KLangpaket ASK coded.
#524
dealers now use piwis 3
what does it mean? you have chinese piwis 2?
