-   997 Turbo / GT2 (https://www.6speedonline.com/forums/997-turbo-gt2-58/)
-   -   p4690 &p4691 code, 997tt some days I get boost done days I don't (https://www.6speedonline.com/forums/997-turbo-gt2/316758-p4690-p4691-code-997tt-some-days-i-get-boost-done-days-i-dont.html)
canada0323 Sep 3, 2013 11:46 AM
08 997tt with turbo boost issues. I get boost at times. But some days I don't. Can anyone help?
therock88 Sep 3, 2013 02:39 PM
Not a lot of info to go by, and I do not think these are Porsche, but rather generic codes. You may want to check to be sure the VTG actuator rods are not sticking. There was a bulletin about putting silicon grease on them as some may stick at times? That may cause an intermittent problem you describe??
Good luck!
DC
GTRNICK Sep 3, 2013 04:19 PM
Could be a vacuum leak or cracked header! Is your car stock?
canada0323 Sep 3, 2013 05:44 PM
Car has carbon fiber airbox and updated programming. Other than that stock. Some days the turbo's boost to 18psi, some days very little boost. Very inconsistent. The actuator rods were regreased recently.
therock88 Sep 3, 2013 09:20 PM
If they were regreased...may want to check and see that one or both were put on correctly and did not pop off? Just a thought. I am thinking a leak would cause boost issues all the time?? Easy to look under the car and inspect the rods to rule that out.... Good luck.
DC
GTRNICK Sep 3, 2013 11:30 PM
DC
I definitely agree with the actuator rods and as for the boost leak it happend to me lol thats why i said it.
Also check the little o-rings on the oxygen sensors as they can corrode as this happend to me too!
GTRNICK Sep 3, 2013 11:32 PM
DC
I definitely agree with the actuator rods and as for the boost leak it happend to me lol thats why i said it but you would think its impossible and it was intermittent for me too.
canada0323 Sep 4, 2013 12:04 PM
Thanks for the feedback. Just picked up car from the shop. Problem is actuator rods sticking. Had them regreased with hopes the problem would be fixed. Nope, worked at first but half way home started sticking again. So this was a problem with these turbos from the factory and now car is or of warranty what are my options? Can I get coverage somehow from Porsche or can the rods be replaced or need new turbos? Help
GTRNICK Sep 4, 2013 12:14 PM
You can get them reconditioned or if you go down that route you might aswell make them hybrids! Speak to Rhonda at FVD and she will help you out. Just exchange them for hybrids would be your best bet! I run the FVD hybrids and they are nice!
Or another option is to speak to Emre at ES Motors as he is one of the best tuners out there aswell but you might end up going for an 850 kit hilarious
One thing I will say is that you might want to get another opinion on the actuators before you do this as they could be trying to con you!
You can put pressure on them for good will but good luck in that happening.
jhbrennan Sep 4, 2013 12:52 PM
What is "updated programming"?
GTRNICK Sep 4, 2013 01:03 PM
Im guessing he means a remap.
therock88 Sep 4, 2013 01:08 PM
That is what I was thinking. And agree....Should probably go to another shop or even good Indy shop and see if they can't get them lubed up to work properly...Other options cost slightly more than $10 :)
Sorry to hear the problems and best of luck getting it fixed.
DC
jhbrennan Sep 4, 2013 07:35 PM
If that's the case maybe go back to stock and see what happens. At least that would eliminate one of the variables.
