Does anyone offer flexifuel ecu for Porsche?
Ecutek has this for the GT-R. You can run either regular pumpgas or e85. in their new version it lets you mix the two, you dont have to run the tank empty before putting in e85 or regular gas, you can mix them and the ecu adjusts. I have never seen anything similar for Porsche turbo. Its just strict E85 if you do a conversion? Is their any tuner that offers flexifuel for Porsche? That would make life much easier if youre considering E85 conversion.
A few tuners do E85 tunes but all of them that I have seen have done fuel upgrades while moving to E85. This leads me to believe the stock fuel setup(either injectors, pump or lines) cant keep up with the fueling needs of E85.
A lot of tuners do Pump and Race gas (100 octane) tunes though.
http://www.ecutek.com/Products/Trade...ntrol-(2).aspx
If you want complete FlexFuel (any blend of ethanol from normal pump gas to straight E85), you're gonna need to go standalone. ProEFI was the first to release FlexFuel mapping, but I do believe that Syvecs & the AEM Infinity also have this feature. Not sure about AEM Infinity, but I am 100% sure that both ProEFI (BBi & Evolution Motorsport both support it) & Syvecs (Switzer) work on Porsches.
EPL has my car tuned for E85 and I also have a 93 map. Keep in mind e85 needs supporting mods for cooling and fueling such as injectors. You just need to download the tune to your laptop off the EPL server and have wifi connected to switch it on your car. They suggest you empty the tank all the way. I only do it in my garage where Wifi is available but im sure there are some sort of tablet devices that can give you internet from anywhere that you can have the software downloaded on and obd cable to flash!
This is one way of having e85 without a standalone ecu, and I have also heard that standalones are great but have no place being in a street car.
Thank you both for your answers. So you have to do a standalone because the stock ECU does not allow it, to bad. A standalone Ecu are a bit to much modifing for me. I was thinking about getting a tune and all the other bits that is needed for e85 and to be able to run pumpgas when needed on my GT2.
There's a reason why some high profile shops are picking up standalones -- BBi & EVOMS both support ProEFI, Switzer uses Syvecs, and AMS has experience with both.
Tony from EPL, who tunes on the stock DME.
For high power setups, a Standalone EMS will allow for the motors full potential to show while offering significantly more protection for the motor. You can only readjust so many OEM tables (that were designed for K24/K18/VTG turbos and very conservative street tunes) before you've exceeded the capability of the factory setup. If we look at some other high HP "street cars", please explain why UGR's Lambos are run off Motec, ProEFI/AEM Infinity on Turbo E46 M3s, ProEFI/Syvecs on the GTRs.
In my case, accommodating an ethanol setup on a budget without a standalone is possible.Not true flex fuel but capability to switch with full potential of each fuel. From my experience I know the stock ecu can safely control high horsepower on built motors like mine for instance with enough power to max out our fuel systems, and even a pair of gt3076 or gt35s on e85 with the capability to adjust tables,control boost smoothly and have stock like drivability. I was skeptical about making the switch over to e85 but it is becoming more available in my area and I never really run 93 anymore for the sake of leaving that power on the table whenever I drive. Addicted to the Tortilla juice.
Good luck!
I will use a socket with 2 chips and a switch.
This is available for the MED7.
So you are able to switch between two
mappings one for "normal" fuel
Or low boost and one for something else.
Regards
Regards
