Garage Ramps and Lift Pictures
10 Attachment(s)
Hi Guys.
Weather has been cold as crap in Illinois for a wile. We had a couple days recently where the temps got near or above freezing so I used the opportunity to finish up my Ramp/Lift project and clean out the garage from the other cars dropping snow terds on the floors! Some members in one of my previous posts seemed interested in this, so I took some pics and posted. I built the ramps with screws, pressure treated 2x4's, 5/8" OCX plywood, Industrial low pile carpet and lots of staples :) You can get the lifts at many places at reasonable prices. You can search Google for "mid rise scissor lift"...then ignore the thong/underwear pictures and go to the automotive section :) Center pieces are held together with door bolts and the whole assembly can be disassembled and moved when the car is up if needed. I also have two screws on each ramp portruding (the head end) from the bottom and a small 1/4" deep whole drilled in the concrete...This keeps the ramps in place when driving up and very simple solution! Capacity is 6000 lbs. Lifts the sports cars easily...have not tried the Cayenne or X5 SUVs yet, but suspect they will pop right up too! Enjoy. DC |
4 Attachment(s)
A couple more photos..
Very nice idea :) I might just copy it.
Andreas |
Wow, very nice! Would you be willing to share what the cost was to build?
Originally Posted by ET1KTRD
(Post 4027059)
Roughly I would say all the ramp supplies were under $200...List and pseudo instructions to follow. I am sure other have better ideas too, but will share my approach for what it is worth. Will post soon... DC |
Very nice work! That is a great project with awesome results.
Obviously the height of the ceiling is a limiting factor and the specs say max height of about 5 feet or so. Have you used it to perform any work yet? Curious as to what that's like, seems you might have to squat a bit to get under that, could be a hell of a leg workout! Multitasking :) |
4 Attachment(s)
OK...here is a very rough and quick plan, but gives the general idea and you can cost from this at any building center. Again, should be around $200 or less.
For the the sloping ends, I found a drop over 18 inches was very slight and will clear the cars spoiler. Just mark back 18" from the end and use a straight edge to angle from that mark to the end of the board. The scrap piece is the exact angle and can be used where I indicated extra support. Good luck..I hope this helps. And note measurement may vary based on the Lift and your preference, DC |
Originally Posted by Kricci
(Post 4027166)
Obviously the height of the ceiling is a limiting factor and the specs say max height of about 5 feet or so. Have you used it to perform any work yet? Curious as to what that's like, seems you might have to squat a bit to get under that, could be a hell of a leg workout! Multitasking :) It is higher than it looks in the photos...and I actually stop it just shy of hittling the openers....It seems plenty high so far....and much better than jack stands and rolling around on the floor. I am a Beachbody coach too and have done all teh P90, Insanity, T25 etc...workouts so if I do need to quat for a while I can handle it...and maybe skip workout that day :) DC |
Originally Posted by therock88
(Post 4027193)
Yeah...Depends on what you are doing, but makes it all a lot easier. Sitting on a work stool or standing if working on wheels or nrakes..it is perfect.
It is higher than it looks in the photos...and I actually stop it just shy of hittling the openers....It seems plenty high so far....and much better than jack stands and rolling around on the floor. I am a Beachbody coach too and have done all teh P90, Insanity, T25 etc...workouts so if I do need to quat for a while I can handle it...and maybe skip workout that day :) DC Great work - thanks for the post/info! |
Looks great!
Originally Posted by mattgarrett
(Post 4027542)
Looks great!
neat and tidy!
Really nice setup. Saw your post on Rennlist and did a search. Some went a step further and cut up the flooring to drop the lift into the concrete. Which lift did you get? Not sure if it's just the photo but there is one pic where the car looks like it's kind of tilting towards the back?
Originally Posted by E55AMG
(Post 4027607)
I bought an Atlas from Greg Smith Equipment in Indiana...It is relatively close and they were willing to ship for not too much and use a gate lift at my house. Many vendors will only pull it to the back of the truck...or require it to be a business address...so that limits selection a bit. DC |
That looks great!! The carpet really added a nice clean look.
