ESMOTOR GT3 intake manifold and GT3 turbo cylinder head package
Old May 14, 2014 | 04:34 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Hello guys,
I would like to show you one of our specific engine developments for 997 Turbo engine.
Our GT3 turbo head and intake manifold package utilizing;
- GT3 Cup heads
Heads are very specially modified to be compatible with 997 Turbo camshafts,
so we can use 997tt cams and still have 750rpm idle and maintain low rpm response and torque.
- Custom valves for Turbo application
Valves are fully custom built to withstand extra heat and pressure inside the turbo engine.
Intake valves are 41mm, exhaust valves are 35.5mm, way bigger than the OEM 997tt.
- Valvetrain parts
Stronger dual valvesprings and retainers are used.
- Intake manifold
Custom designed to minimalize pressure and flow difference across the cylinders,
while maintaining low-mid rpm response.
- Throttlebody
82mm GT3 or our billet 90mm throttle can be used.
Results are very promising so far, we made comparison with 2 different cars with same setups except the heads,
this head made around 0.5 seconds difference on a 60-130mph run at 15psi (1bar) of boost.
here are some pictures;
ID:	374550   Click image for larger version
ID:	374551   Click image for larger version
Old May 14, 2014 | 08:33 AM
looks awesome
#TeamAIM
Old May 14, 2014 | 10:19 AM
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
Great job Emre! Looks great....
Old May 14, 2014 | 02:58 PM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Now that is is a work of art.
Old May 14, 2014 | 05:26 PM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
One word
Arts
Keep it up
Can not wait to receive my engine 1000hp back from you
Old May 14, 2014 | 06:29 PM
greekc6's Avatar
Beautiful work as usual emre. Keep up the great work
Old May 14, 2014 | 07:19 PM
shonuf's Avatar
Member
shonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to beholdshonuf is a splendid one to behold
Hello Emre,
Are the heads CNC match ported as well as matched to the intake runners?
Do the pistons need a larger radius flycut?
Old May 15, 2014 | 02:18 AM
Thank you all for your kind words..
Shonuf,
Heads are port matched with intake runners,
and yes pistons need different valve reliefs as valves are significantly bigger compared to stock 997tt.
Old May 15, 2014 | 06:44 AM
webcarconnection's Avatar
webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !webcarconnection Is a GOD !
The intake manifold can be use with the stock heads? It will fit 997.2TTs?
Old May 15, 2014 | 07:14 AM
Hello,
Cant be used with stock heads, you need bigger ports.
It won't fit on 997.2TT.
Regards,
Emre
Old May 15, 2014 | 04:08 PM
Fadi's Avatar
Fadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond reputeFadi has a reputation beyond repute
Congrats, looks like a piece of art and i assume it will make a huge increase in performance for any of us
these heads with a new gt3 crankshaft will allow 8200+ rpms without beating everything inside the engine ?
low idle and good mid rpms power is very good news, but will the engine continue to produce more power after 7000rpms using regrinded 997tt cams ? how would you compare the top end vs a gt3 street cams engine ?
what are the benefits compared to ported 997tt heads with bigger aftermarket valves, springs, etc..
Old May 16, 2014 | 07:23 AM
This setup is made to fully benefit from 997tt head system, so you can still retain vario lift and make power till 7500rpm.
to rev higher (7800+) you need to change the valve tappets with solid ones like the on the GT3 head system.
Old May 16, 2014 | 11:56 AM
Chkmgnt59's Avatar
Chkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud ofChkmgnt59 has much to be proud of
Do you have a listed price for these yet? Or is this a 'if you ask, you can't afford it' type thing :-)
Old May 16, 2014 | 12:16 PM
yumaverick's Avatar
Originally Posted by chkmgnt59
do you have a listed price for these yet? Or is this a 'if you ask, you can't afford it' type thing :-)
$3,500
Old May 16, 2014 | 12:27 PM
Chkmgnt59's Avatar
$3500 for the heads and intake manifold? If that's true then that is surprisingly low vs what I was expecting.
