997.2TT guys..... what tire pressures are you running on the street?
Old Aug 5, 2014 | 07:22 AM
NickS's Avatar
NickS is infamous around these parts
My car oversteers like crazy with the F&R factory recommended pressures. Even reducing the pressures to 37F & 40R still doesn't resolve the issue.
Old Aug 5, 2014 | 07:53 AM
90sundevil's Avatar
90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of90sundevil has much to be proud of
I don't have that problem and put enough air to stop the TPMS from lighting up.
Old Aug 5, 2014 | 08:15 AM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
If you are over steering, assuming your suspension is good, I think you are over inflating your tires. Try 35 in the front and 37 rear
Old Aug 5, 2014 | 10:51 AM
longboarder's Avatar
Are you sure that it oversteers? Other than the snap oversteer characteristic of these cars when cornering aggressively with stability control disabled, it is designed to significantly understeer from the factory....which is a good idea given that it's a 500+ HP car that is typically bought by people who don't know anything about driving. So the understeer characteristic probably saves an untold number of lives.
But lets assume that you drive the car hard with PSM disabled and you want to dampen the snap oversteer associated with a very powerful rear-engine car. You need to rear end to be "planted" as firmly as possible. And frankly you aren't going to accomplish that with tire pressure alone. A good start is rear end dog bone/end links, good tires and an alignment to match your driving style. Also, this work should be done by someone that actually races 911's.
Of course this is just a start. If you want to tighten up the rear end more and hit the track, then you need to get a good set of coils, dial in a lot of neg front camber, and you can have a car that handles like a GT2. Unfortunately it will take around $10K.
Old Aug 5, 2014 | 04:02 PM
997.2 TTS's Avatar
997.2 TTS is infamous around these parts
34f and 40r is what I find comfortable with a good feel.
Old Aug 5, 2014 | 07:37 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Those aren't the factory pressures.
Those are the factory numbers. I had the dealer set to the door settings as well. If you check the manual, the factory pressure settings are 34/40. Comfortable ride and seems like perfect traction and balance. I'm a bit curious why they changed from the .1, which had recommended 33/39. Don't set the your tires according to the max settings on the door jamb.
Old Aug 5, 2014 | 08:04 PM
Turbo Ron's Avatar
Turbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to all
I running 38 front and 43 rear
Old Aug 5, 2014 | 08:37 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
33 / 36 for me in general, but I have a highly modified suspension. On the track I start with 28 all around cold and keep it to more than 37 hot. I run Michelin PSS all around.
Old Aug 6, 2014 | 05:48 AM
NickS's Avatar
I would say because at those lower pressures, the insides of the rear tires will wear faster than if the pressures were set higher.
Old Aug 6, 2014 | 10:37 AM
Curious why you track with PSS. I tried once and it was downright dangerous. They melted and turned to grease. They are a 300 treadwear street tire so they aren't designed for heavy track use.
Old Aug 6, 2014 | 11:18 AM
DNugget991GT3's Avatar
33 front 37 rear here
Old Aug 6, 2014 | 10:48 PM
Zero911's Avatar
Zero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to all
34 f and 40 r for me.
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
