Switzer E911 take 2 review/install
#122
Switzer E911 Β take 2 review/install
Originally Posted by vr6tee
I think it's a bot doing that.
I too spoke with Switzer about this kit. I'm less than 2 hours from them and I got some conflicting reviews from people here in Ohio that have used them. In the end I decided to compile my own components.
I'm glad you got it all sorted a less capable person with the spanners would have had a hell of a time.
#123
exactly. plus you dont want to be in position where fuel system is no keeping up and ECU is doing something to compensate especially when you are at the limit of the injectors. i would try bumping the base to 55psi with no vaccum on the regulator and see where that gets you, and if it makes it any better. if it stays the same or gets worse, i would turn the power down a little.
I did go to a closed course yesterday with a friend and his low 12 second mustang. From 50-160 I made up about 2 city blocks on him
#124
I'm up to 60 psi w/o vacuum. It appears to have made the difference I needed. I've only done one drive since and the wife was in the car yelling to slow down looking at the logs I think I've opened up about 10%. Perfect! Ryan made an adjustment for the added fuel and a more aggressive wastegate map in gears 1-3 as load is lighter and I wasn't seeing my target boost.
#TeamAIM
#TeamAIM
#125
I'm off to Vegas tomorrow for a week. Yumaverick, I should stop by and BS about Porsches sometime this week....
#126
yeah would be cool to see if that dip is gone now. im sure ryan can sorta predict that from comparing before/after logs too.
#TeamAIM
#TeamAIM
#135
that was Anthony and John
#TeamAIM
#TeamAIM
panas001
09-27-2015 02:51 PM
