Steering wheel swap from 991.2TT to 997
Old Aug 10, 2019 | 06:52 PM
  #181
Originally Posted by Oran C
It's an informative thread. I'm still confused if I need the steering column module. My car is 2007 987.1 Boxster, manual with non-MF wheel. If I swap in a 991.2 manual non-MF wheel, do I need that module ? I read other posts they just did a direct plug and play for their 987.1 cayman/boxster.
Appreciate any input.
You do not need the module for the non-multifunction wheel.
#TeamAIM
Old Aug 10, 2019 | 10:18 PM
  #182
Oran C's Avatar
Oran C is infamous around these parts
Is the horn gonna work without that module ? is that module only serve the purpose for the MF ? or it's somehow related to the horn ? Thanks.
Old Aug 11, 2019 | 05:54 AM
  #183
Horn will work.
#TeamAIM
Old Aug 12, 2019 | 12:41 PM
  #184
3llooi's Avatar
3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !3llooi Is a GOD !
Originally Posted by Mark @ AIM Performance
Horn will work.
What about paddles for PDK for non MF version?
Direct swap too?
Old Aug 12, 2019 | 01:23 PM
  #185
shadow993's Avatar
shadow993 is infamous around these parts
Direct swap too?
It will all work with the new style wheel. The 991.2 not the old paddle style.
The only thing that will not work is the plug and play is MF. Suncoast sells blanks to eliminate the MF switches.
Old Aug 28, 2019 | 10:22 PM
  #186
STIG's Avatar
STIG is infamous around these parts
hi shadow,
I need to get a 991.2 pdk wheel to replace my 2007 997.1 tip wheel. How do I get in touch with you? Doesn’t appear I can send you a PM due to my low post counts?
Old Aug 29, 2019 | 06:34 PM
  #187
shadow993's Avatar
I sent you a PM
Old Sep 4, 2019 | 04:27 PM
  #188
CELES's Avatar
CELES is infamous around these parts
Volante
Ok
Old Sep 4, 2019 | 04:28 PM
  #189
CELES's Avatar
Yo se lo instale en mi coche
funciona ok
Old Oct 4, 2019 | 08:40 PM
  #190
jgoga's Avatar
jgoga is infamous around these parts
Originally Posted by jayi836
Ebay otherwise Suncoast.
Macan wheel will require the GPS Adapter.
I don't think Porsche makes a heated CF wheel.
I have a 997.1 manual. I do NOT have MF and do not care for MF. In this case, do i need the steering wheel and the new air bag from a 2016 or newer Macan? I could get the blank inserts from Suncoast along with the shroud part#: 95B419798B5Q0. Is there anything else that i need besides this? I understand he horn might not work until i have the dealer recode my current module to a MF. (From my understanding, this coding allows the power to the horn) If i want to install this wheel style:
Regards,
John
Old Oct 5, 2019 | 11:52 AM
  #191
shadow993's Avatar
Regards,
John
Correct! Any new style wheel and airbag works. The airbags are interchangeable.
You can also remove the paddles in 5m, and porsche sells a tee cover for manuals.
I highly doubt you will need programming for the horn.
Old Oct 8, 2019 | 09:45 AM
  #192
jgoga's Avatar
Thank you so much.
John
Old Oct 8, 2019 | 09:50 AM
  #193
I have a 997.1 manual. I do NOT have MF and do not care for MF. In this case, do i need the steering wheel and the new air bag from a 2016 or newer Macan? I could get the blank inserts from Suncoast along with the shroud part#: 95B419798B5Q0. Is there anything else that i need besides this? I understand he horn might not work until i have the dealer recode my current module to a MF. (From my understanding, this coding allows the power to the horn) If i want to install this wheel style: https://www.youtube.com/watch?v=kxGI5hhHk3k
Regards,
John
Manual non multifunction is just a straight forward swap. Take a new style wheel with a new style air bag and install it and it will work plug and play. You can use any sterring wheel and remove paddles from it as mentioned earlier. If you get a good deal on a nice MF wheel, you can remove the buttons too.
#TeamAIM
Old Dec 7, 2019 | 12:02 AM
  #194
PCCBLOVER's Avatar
PCCBLOVER is infamous around these parts
I have a 2009 6MT 997.1. Turbo
My car did have MFC and i installed a 991.2 Carbon Wheel with Heating
After installing the Horn does work although the MFC nor the Heating work
can someone relay the part number i need from Porsche to enable Heating and MFC
I can verify i did have my dealer try to enable MFC and nothing happened,
thank you
Old Dec 7, 2019 | 10:01 AM
  #195
NJB997's Avatar
NJB997 is infamous around these parts
I worked with Ryan at Vivid Racing to have an OE blank hand made to my specs, then it was a straight swap of steering wheels. Note how well they matched the leather color on the new sport grips with my OE airbag cover.
