Steering wheel swap from 991.2TT to 997
#91
Originally Posted by trbofvr
How much thicker is the 991.2 steering wheel compared to the 997.1? Anyone have any side by side pics? Are 991.1 and 991.2 the same thickness?
There is a huge difference in paddle throw. I would say it's equal to or shorter than the 997.2/991.1 GT3 paddle throw. Plus you get multifunction with the 991.2.
#92
There are a few 997.1 wheels with and without thicker padding option - which one do u have ?
#93
How did this go? I have a 991.1 with a MF wheel. How can I upgrade to a smaller 991.2 MF wheel? Is it plug and play or will it need an adapter with extra wiring?
Thanks in advance.
#94
I guess I had the standard wheel, this is thicker than the stock wheel that came on my 997.1 turbo tiptronic.
#95
What's required to do a GT2RS wheel on a 997.1 6-speed? I have the triangle airbag, so I know I need to get a round one. I don't care about multifunction, I can turn ***** on the PCM .
Anything else required? Seems like all I need is the wheel and airbag.
#96
no affiliation - but what a steal. even comes with the better looking black inserts as well.
http://www.ebay.com/itm/Macan-Heated...1ZU59c&vxp=mtr
#97
and PIWIS coding to turn 'multifunction ON' which will activate your horn. if it doesnt work then u will have to swap out the steering wheel module to the newer one.
#99
Wheel... airbag... Adapter module from https://gpsadapter.us/
Possibly programing by Porsche. I did not and didn't have MF in my 997.1
You do not need the Porsche steering wheel module if you have a 997.2
#100
#101
Originally Posted by Domer911
so since I have 997.2 (without MF), all I need is wheel and airbag, and once I plug it all in, it will play nicely? Even the MF?
#102
Any pictures of anyone doing this procedure with adding the adapter step by step. I an very handy, but want to make sure I know what Im geting into before I jump in with both feet.
#103
If you are asking about the MF adapter, this link has a step by step. https://gpsadapter.us/ However, I did it without removing the wheel, and put the MF adapter by the heater button instead of stick it in the 991.2 steering wheel MF module.
