Help pls: clutch is much heavier prior to starting car in morning - leak AGAIN?
Old Apr 4, 2016 | 10:47 AM
cannga's Avatar
Hi guys, just curious about forum inputs before calling/bringing car in. Car had slave cylinder replacement in past, and a couple months ago again had slave cylinder/master cylinder replaced.
I daily drive the car and typically in morning clutch is very light when I step on it to start car. For past week this first step-on feels very heavy, surely much heavier than previous. Once started, clutch is light again and operation otherwise normal.
Anyone with similar experience? Is it sign again of yet another impending leak in the system? Do I need to top up on the fluid? Thanks in advance.
Old Apr 4, 2016 | 11:19 AM
A418t81's Avatar
A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !A418t81 Is a GOD !
Your accumulator is starting to fail. What happens first is it won't hold pressure over night. Next you will start to notice some subtle pulsation in the pedal when you press it in. This part is different from the slave. It's the black canister next to the slave on the transmission. Not Terribly expensive for another one plus install
Old Apr 4, 2016 | 11:30 AM
Turbo Ron's Avatar
Turbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to allTurbo Ron is a name known to all
I had replaced an accumulator on my 996 twin turbo. It cost about $500 if I remember.
Old Apr 4, 2016 | 12:04 PM
saabin's Avatar
saabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond repute
Had both of these EXACT symptoms with mine. CPO replaced the accumulator and it feels much better now.
Old Apr 4, 2016 | 12:25 PM
cannga's Avatar
Thanks guys for the very helpful replies. Sigh - yep I had that one replaced too. This system (and various other leaks - coolant leak, wing hydraulic leak, turbo leak, I've had them all ) is the biggest problem for our Turbo for sure.
How long do I have to bring the car in? Is complete failure imminent?
Old Apr 4, 2016 | 12:37 PM
saabin's Avatar
Mine felt funny for at least a year before the dealer finally agreed it wasn't right..
Old Apr 4, 2016 | 02:09 PM
Steve_TT's Avatar
Steve_TT has a spectacular aura aboutSteve_TT has a spectacular aura about
I have the same experience. The pedal goes stiff when left over night. I had the accumulator replaced, but it did not solve problem. Can't remember if the shop said it could be the slave or master cylinder. In any event, I left it as is and I've had the overnight stiff pedal syndrome for about 18mos. I check the fluid periodically and it's always fine. I guess I'm waiting for a different sign of imminent failure before replacing.
Old Apr 4, 2016 | 04:29 PM
A418t81's Avatar
There's no rush. Just keep an eye on the slave reservoir under the hood and make sure it isn't pushing fluid out and you'll be fine. I dropped all that crap in the trash and installed a BBi slave. Glad to be rid of that failure prone system.
Old Apr 4, 2016 | 07:16 PM
Al Nunez's Avatar
Al Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to allAl Nunez is a name known to all
I have a slave and accumulator I removed from my car. I replaced it with a new one because I removed my engine. Never had any problems with it so if you need it I can let it go very very cheap
Old Apr 4, 2016 | 07:23 PM
Kricci's Avatar
Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !Kricci Is a GOD !
+1 on this. I did the same and very happy.
Old Apr 5, 2016 | 08:19 AM
cannga's Avatar
Thanks - I haven't been to the forum for a while and just now read up on the BBI slave http://housemotorsports.com/bbi-auto...turbo-996-997/ .
Could you (and Krici) comment on the stiffness of clutch after BBI slave install? How does it compare to GT3/GT2 clutch stiffness? TIA
Old Apr 5, 2016 | 09:41 AM
Johnny DB's Avatar
I'm also thinking about the BBI setup...
Old Apr 5, 2016 | 04:02 PM
au2bahn's Avatar
au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !au2bahn Is a GOD !
Need to get me one of these? Do you need an upgraded accumulator for these or deletes them completely?
Old Apr 5, 2016 | 04:15 PM
Kricci's Avatar
It's difficult to say for sure as I upgraded to a heavier duty clutch to handle my power upgrades at the same time. It is more stiff however it feels significantly more connected/direct than before. I love it. I'd say it is on par with the gt2 conversions ( I only sat in a gt2 and depressed the clutch a few times, so not much time to compare) but maintains stock lines with no need for caps/plugs or tapping the transmission in the other kits. The shop that did the install was very impressed with the BBi setup.
Old Apr 5, 2016 | 04:38 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
It could also be that some dirt got in there when they changed the parts. I had that issue and a good clutch fluid flush fixed it. Not that it can't be the accumulator and most probably it sounds like it does, but the dirt could also be a cause.
