997.1 tiptronic " clunk "
Old Jul 25, 2016 | 04:00 PM
977ttblue's Avatar
977ttblue is infamous around these parts
Hi guys , lately i had clunk while engaging the tiptronic gear R , D or D ,R , i thought that this clunk comes from the gear mount so i changed it ( gear mount ) , but still have the same issue " clunk while engaging the gear " does the transmission upper bracket or side member solve this ?
Any one had the same issue ?
Btw while driving i dont have any problem
You can see parts in the pic
Old Jul 25, 2016 | 04:30 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
I think it is normal.....
DC
Old Jul 25, 2016 | 07:53 PM
cdk4219's Avatar
cdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to allcdk4219 is a name known to all
Transmission carrier, part #1 can be worn or loose. Clunk can come from this. Typically the 722.6 is soft engage into gears, and doesn't clunk. Please check the wear of the "carrier" and rear motor mounts that may have dropped.
Old Jul 26, 2016 | 04:09 AM
977ttblue's Avatar
Thank for sharing me the issue
Does the motor ( enging ) mount cause a clunk in the transmisson while engaging , also i want to notice that i changed the transmisson mount , do you mean by " carrier " the gear mount or something alse ?
Old Jul 26, 2016 | 01:07 PM
cdk4219's Avatar
Part # 1 on your diagram 996 375 033 03
Old Jul 26, 2016 | 01:10 PM
977ttblue's Avatar
Already changed
Old Jul 28, 2016 | 05:54 PM
cdk4219's Avatar
Sorry didn't see that you replaced that. Sounds like the next step is to put it on a lift with someone inside and under, and duplicate the sound. It may be something loose.
charlie1
Mar 30, 2016 08:07 PM
REDNOSEGT
Bentley
Mar 25, 2016 11:07 AM
EM 996 GTS
Sep 15, 2003 05:33 PM
mumanoff
Aug 19, 2003 06:43 PM
boca996
Jul 21, 2003 03:53 PM
