991/Macan Steering Wheel Retrofit-Multifunction button Help!
2 Attachment(s)
Hi guys, i fitted this wheel a few weeks ago, and its really great.
The Paddles have a much shorter and precise throw/click, then the 997.2 Sport Wheel. It was a simple fit as a I already have a 997.2 steering control module fitted. Everything works perfectly except for the Multifunction Buttons. If anybody has a work around on how to get the Multifunction buttons to work, please help! |
In case anybody wants to do this, go here www.gpsadapter.us
I fitted the adapter today, it was really quick and easy. No programming necessary, as I was already set for mutifunction. Works flawlessly, real plug and play. My Turbo is a 2007 with PCM3 retrofit. One of the best and most simple mods, that works out the box (Like DSC) that I've yet done. |
So jealous !
did you also change your gauges to black, and re-upholster with houndstooth?
The seat covers were done by Bob Budd, came out superb 👍🏻 |
Do all the multi function buttons work ? Any error codes ? |
I've used the adapter linked above and all buttons work as they should with no error codes.
Quick question along the same lines as my TTS is stored; does it have a heated steering wheel? I don't think I have ever looked. If not and I buy the heated multifunction 991.2 wheel, can I have it programed to turn on? Where would the on / off switch be located? On the wheel or needed to be on the column previously ?
If you have 997.1 so no chance to get heated steering wheel... Even with changing steering column control unit to 997.2 version... Had tried lots of coding but no help
https://cimg0.ibsrv.net/gimg/www.6sp...3d7b86fbe6.jpg https://cimg0.ibsrv.net/gimg/www.6sp...141a9e4cf4.jpg https://cimg9.ibsrv.net/gimg/www.6sp...b2db35aaed.jpg https://cimg9.ibsrv.net/gimg/www.6sp...076da7e90b.jpg https://cimg0.ibsrv.net/gimg/www.6sp...140be8d8b7.jpg
Originally Posted by Vital Signs
(Post 4758840)
