Tire Pressure Light , but tire pressures are good.
Old Jul 18, 2017 | 07:32 PM
bigrpowr's Avatar
bigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nicebigrpowr is just really nice
i assume the sensor has gone bad, but it's only a year old or less. it says it's down 4 psi even though its actually at 38 where it should be. any insight would be great .
Old Jul 18, 2017 | 08:49 PM
Pendl303's Avatar
Pendl303 has a spectacular aura aboutPendl303 has a spectacular aura about
Mine literally did the same thing today, i put 1psi more in and it shut off
Old Jul 19, 2017 | 11:26 AM
emerica4601's Avatar
emerica4601 is infamous around these parts
I'm having the same issue right now as well
Old Jul 19, 2017 | 11:35 AM
Skwerl's Avatar
Skwerl is infamous around these partsSkwerl is infamous around these parts
Same here. Last night it even had a scary red "FLAT TIRE!!" warning, even though pressures were fine. I've heard pumping them up to higher pressures can help resettle the sensor. Another tactic is to add air and toggle between summer/winter and full-load/partial-load settings in the menu to recalibrate.
Related question: we've all heard about how improperly sized tires can wreck the differential - how about if a couple tires are underinflated?
Old Jul 19, 2017 | 12:20 PM
turboslut's Avatar
turboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant futureturboslut has a brilliant future
Most TPMS failures are caused by tire pressure sensors that have reached the end of the road. The batteries inside the tire pressure sensors have a service life that typically ranges from 5 to 7 years. The service life can vary depending on how many miles a vehicle is driven (the more it is driven, the more frequently the sensors generate a signal and drain their batteries).
Part Number: 997-606-021-01 (OEM)
Aftermarket:
http://www.titantpms.com/tpms/porsch...SABEgKBrfD_BwE
Old Jul 19, 2017 | 02:53 PM
damon@tirerack's Avatar
Moderator
We have sensors if needed. Most run about $90 each for Porsche.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Jul 19, 2017 | 06:57 PM
bigrpowr's Avatar
i bought them from you buddy !!
