Advice with P1539 and intermittent oil gauge fault
Old Jan 5, 2018 | 03:28 PM
onefastman1's Avatar
onefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to allonefastman1 is a name known to all
I have been getting intermittent oil gauge faults after changing my oil from standard synthetic to motul 300v along with a P1539 code.
I don't know if the two are related but I have driven two thousand miles with the car without issue.
I was thinking it was a wiring issue as both sensors are on the passenger side of the engine but I checked and there do not appear to be any wires grounding out or loose connections.
Any other ideas?
Old Jan 11, 2018 | 09:50 AM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
I believe the oil gauge can go wonky once in a while. I fixed mine by disconnecting the battery for a day. Never had an issue for 2 years after that. However it also didn't throw a code.
nomrad
Jun 23, 2017 07:53 AM
toughluck
Feb 25, 2014 08:42 AM
Pkhoffman
Feb 21, 2012 01:29 PM
blue911tt
Apr 22, 2010 05:38 PM
Jgalt
Mar 7, 2010 11:47 AM
