5 bar fuel regulator need details
So after doing a Dyno run I found out my car must have a tune. It has no bolt one but has 505 at wheels on a mustang Dyno (620+ at crank) 132 trap speed in 1/4 mile. Someone said I could easily get more power by putting a 5 bar fuel pressure regulator (if I listened properly to their wording). Is this a quick way to add HP? Are there any other little tricks that add HP like this? Is the 5 bar regulator a legit gain? Is it expensive labor to switch it out?
If you were near your fuel capacity & got a re-tune for the 5BAR (ie more boost/timing/more octane if needed etc) then yes....but by itself NO. If you even put the 5BAR in you most likely might need a new tune for the extra fuel you have now introduced to the mix, EVEN if it didn't add anymore power.
No it is not hard to install the FPR.
I don't see how you could make those figures with the original injectors/fpr.
So i would assume either bigger injectors or a fpr are already fitted.
Should be possible to see in the tune.
So i would first start of with figuring out exactly what has been done by the previous owner.
How to?
