-   997 Turbo / GT2 (https://www.6speedonline.com/forums/997-turbo-gt2-58/)
-   -   Service "to do's" while dropping motor for new plugs/coils (https://www.6speedonline.com/forums/997-turbo-gt2/424730-service-dos-while-dropping-motor-new-plugs-coils.html)
wkp42 Sep 28, 2018 02:37 PM
Hello All,
I am taking my 997.1 TT in to have the coils and plugs changed. What else do ya'll recommend to have done while the motor is dropped? Car has 80k miles on it. Any other major service I should have done while it's in the shop? Any common failures at this mileage I can get ahead of?
lliejk Sep 28, 2018 06:53 PM
You will get a lot of good advice, but my plans are:
1. Re-glue/Pin Coolant lines
2. R&R hoses/elbows (use Sharkwerks)
3. Inspect, R&R any vac lines, etc that might need attention
If something else comes up at that time, even if I didn't have to drop it to deal with, I would be doing that as well, including things like the clutch & clutch hydraulics.
Ed
Skwerl Sep 28, 2018 10:06 PM
Preventative water pump replacement, especially if it's the original one.
wkp42 Sep 29, 2018 09:32 AM
water pump was replace 8,000 miles back
wkp42 Oct 2, 2018 04:21 PM
Anything else?
What else should I get done? Any more feedback?
wkp42 Oct 2, 2018 04:22 PM
Ed
thanks for the feedback
lliejk Oct 2, 2018 05:02 PM
I did some more reading, mostly the same with some additions, but just to reiterate:
1. Coolant Lines pinning/re-glueing
2. Metal Elbows
3 R&R all hoses (saw someone add the expansion tank to the list
4. R&R vac lines
5. Water pump if needed
6. Clutch if needed
7. Clutch Hydraulics if needed
8. Accessory Belt if needed
9. Throttle Position Sensor if needed
10. O2 sensors if needed
11. Change out ALL fluids
12. Camshaft Pinning - controversial if needed, most recommend to not do this proactively and point to the actuators being left to slowly die being the true culprit or even dirty oil clogging the works up causing issues
13. Mods - IC's, Exhaust, headers, etc
14. Every rubber fitting/o-ring, mount etc. on the car/engine
There might be more but that list feels pretty complete. Obviously there are other sensors and electronics, but I think the focus should be on the rubber/wear items and high probability failure electronics.
Ed
wkp42 Oct 2, 2018 05:44 PM
2. Metal Elbows
4. R&R vac lines
6. Clutch if needed
Ed
thanks for the feedback. Do these cars have EGR valves?
nzskater Oct 3, 2018 12:11 AM
The secondary electric water pump for the turbos is worth considering. Also look to check and secure the FPR line at both ends.
brnrdtns Jun 29, 2020 01:51 PM
Prob don't need to mess with your AC if it isn't broken.
lliejk Jun 30, 2020 08:54 AM
Whenever faced with boost issues on a turbo engine, I do a boost leak test as a first step.
Ed
