Go Back  6SpeedOnline - Porsche Forum and Luxury Car Resource > Porsche (Present) > 997 Turbo / GT2
Reload this Page >
Capristo Spring Cleaning- Special Pricing 997 Turbo Complete Exhaust
Notices
997 Turbo / GT2 20062012 Turbo discussion on the 997 model Porsche 911 Twin Turbo.
Old 03-07-2019, 05:27 PM
vividracing's Avatar
Premium Sponsor
vividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond reputevividracing has a reputation beyond repute
Hey guys! Capristo is one of the absolute best and highest quality exhaust manufacturers on the planet; and we are currently running a spring cleaning sale on a few systems. We have a 997.1TT and 997.2TT full valved exhaust systems in stock right now for this sale.
These are complete turbo back systems, equipped with 200 cell sports cats, CES-3 remote control system, and ceramic coated end pipes.
The complete CAPRISTO high performance system is intended to be a balanced increase between power, drive ability and sound quality, without forgetting of course a substantial loss of weight. All of this is delivered while maintaining the CAPRISTObest of both worlds philosophy which provides the capability to produce an aggressive exhaust note under acceleration and a more subdued sound for city driving. An additional 60Nm 90Nm and approximately 50hp increase was measured in the lower range of rpm. In the upper range of rpms it was an increase of approximately 15hp.
This feature is possible using vacuum-actuated valve flaps that open and close depending on driving conditions and input from the driver. At lower engine speeds and during cruise operation the valves are closed and produce a deeper exhaust note. At wide-open throttle, the valves open releasing the full symphony of the engine.
The exhaust valves are backpressure-controlled and via the included Valve ControllerRemote which allows you to control the flaps to open permanently, without the in-series control being able to intervene. When the exhaust valve system is closed again with the use of the remote control unit, then the in-series control unit will again take over the control of the exhaust valves. This allows precise control of the exhaust based on the drivers personal tastes and tolerance.
CAPRISTO Exhaust systems are engineered and manufactured utilizing advanced 3D Laser-Scanning, CAD Design, Digital prototyping, and CNC-bending/milling at our factory in Germany. Each system is made of high-grade T309 (1.4828) Stainless Steel and hand polished to a mirror finish. After extensive research, this specific alloy was chosen for its sonic resonance properties, low weight, and durability which are close to the properties of Inconel (used in F1).
SPORTS CATS 200 CELL:
The High Performance Sports Catalytic Converters feature 200 cell per square inch substrate fashioned from the highest quality materials currently available designed to improve air flow for your vehicle and increase performance.
The cell count of a catalytic substrate refers to the number of holes per square inch and is a direct indication of the flow capabilities of that substrate. The lower the count of holes the bigger the hole need to be to fill one square inch, a bigger hole subsequently flows more exhaust gasses.
All of this High flow will not help if the substrate is squeezed into to small a diameter can or pipe. For this reason, CAPRISTO Sports Cats come packaged in 5.2 inch packages to maximize exhaust gas flow and operation of the valved exhaust system.
997.1TT
997.2TT
AUSTIN - Porsche Performance
1.480.966.3040 x246 / [email protected]
Porsche Performance Store // 997 996 Turbo ECU Flash // Cayenne ECU Tune // Boxster Cayman Flash // Carrera Tuning // Panamera Tuning
997 Turbo Vendor Classifieds
03-06-2019 11:34 AM
intrepidagent
28
05-16-2018 09:10 AM
intrepidagent
Merchandise For Sale / Wanted
02-14-2018 06:23 PM
intrepidagent
991 Vendor Classifieds
02-04-2018 12:25 PM
Quick Reply: Capristo Spring Cleaning- Special Pricing 997 Turbo Complete Exhaust
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
