997TT Gear Ratios and Speed to Gear Ratios -INFO-
Just in case anyone was wondering what the gear ratios was for the Tip and Manual on the 997TT. And also the speed to gear ratio on the Tip S. :)
TIPTRONIC S / MANUAL Gear 1. 3.59 / 3.82 2. 2.19 / 2.14 3. 1.41 / 1.48 4. 1.00 / 1.18 5. 0.83 / 0.97 6. ---- / 0.79 Gear to Speed km/mph Tiptronic S Gear km / mph 1. 75km / 47mph 2. 124km / 77mph 3. 192km /120mph 4. 271km /169mph 5. 326km / 204mph |
You truly are a mecca when it comes to 997TT info! Thanks!
No im not.... I just drop off here all the info I pick up here and there ;)
But thanks!!! |
any info on 6mt gear to speeds?
Originally Posted by Jas0n
(Post 543713)
Originally Posted by Roffle Waffle
(Post 4643066)
bump. Also looking for this info
depends on redline rpm in the tune and tires you are using. |
6750 rpm, -305/30/19
I believe those are stock sizes and rpms, not sure how people are hitting 60-130 in 4th. I think my 4th ends closer to 125 |
You will not hit 130 with stock redline, needs 7.0-7.1 redline to get there in 4th ... You can find the gear ratios and speeds in the owner's manual
