Daytime Running Lights are kinda weird
So I activated the DRLs via sport chrono menu, and not only do the headlights come on, but so do the side markers and tails. Not exactly what I was expecting. was hoping for headlights only. Is there a way to change this, or is this the way Porsche does this?
You could take your car to the dealer and ask them to program yor lights for Canadian lighting. I think the headlights are the only item turned on.
That's a good idea. I just find it strange that porsche programs all the lights to come on as DRLs.
My Canadian car (not imported) has all the lights on for DRL. The only thing the dash switch does is turn on the dashboard and instrument lights (and front & rear fogs if I want). I thought that was standard.
I have seen other 997's with just the headlights on. My car is a US car wth the DRL's turned on via the PCM.
Perhaps they have rewired the the car, thanks for the response John. |
I have a US car which the dealer turned on the DRL because I was importing it to CANADA and all the lights come on except for the dash as well. Never understood why the tail lights would go on as well.
I had dealer enable DRL in my car. However, after few weeks I decided to go back to the dealership to turn off DRL. I did not like at all the fact that all lights come on.
DRL Canada - what is the standard set up?
My Canada car only has the LED lights that come on as part DRL e.g. regularheadlights do not come on. I went into chrono and there is no option to turn the DRL function on or off?
For the 997.2 cars (2009) there is an option to configure the DRL's in the computer. It may depend on having the sport chrono option, otherwise the dealer may need to program the option. I have mine set to use DRL. What this does in the car is turn on the front LED DRL lights in the bumper.. thats the ONLY lights that are on when the engine is running, unless I turn the light switch to turn on the lights (headlights and tail lights / running lights).
How things work on a 997.1, without the LED DRLs is a different issue, and it seems specific countries have specific rules. |
Originally Posted by Minok
(Post 2534958)
Anthony |
My '09 car came with a unique feature - an Owner's Manual - could be USA/GA only? :rolleyes: For those without it, here's what it says:
Daytime driving lights The daytime driving lights are integrated in the front auxiliary headlights. These lights are switched on only when the engine is running and with the light switch in the positions OFF or HOME. Operation of the daytime driving lights may vary depending on country-specific regulations. Canada only: In addition to the auxiliary headlights the parking lights are switched on. USA only: The daytime driving lights can be deactivated in the on-board computer. > Please see the chapter “ON-BOARD COMPUTER (BC)” on Page 128. Vehicles with the Sport Chrono Package Plus Further individual light functions (e.g. daytime driving lights) are available in vehicles with the SportChrono Package Plus. > Please observe the chapter “Individual Memory” in the separate PCM operating instructions. |
I believe the original question pertained to 997.1 cars, which don't have the new LED DRLs. I found that on my 05 C2S cab with sport chrono, I still couldn't program DRL. Apparently the early PCMs didn't provide that option. My 07 T4S allowed me to set up DRL, which is all the external lights. So I view it as a compromise to the normal DRL setup which would be headlights (or preferably, other front lamps) only.
I ran across this hack on a 2000S Boxster, but have not tried it yet....
I have a 08 997 and will try it sooner or later as it sounds reasonable to me. DRL-Fog Light Hack The hack involves a single jumper wire between the Fog light relay and the Fog light fuse. Now the Fog lights go on and off with the ignition switch and are switched off when the high beam headlights go on. Required Materials: (10) inches of 16 gague insulated wire (2) Fuse taps, Radio Shack P/N 270-1204 (2) female Quick Disconnectors, Radio Shack P/N 64-3131 Procedure: 1. Strip the wire ends and crimp on the Quick Disconnects. 2. Plug in a fuse tap to each of the Quick Disconnects. 3. Locate the Fog light relay in the panel above the Fuse panel. It is #12, the far left relay in the second row from the bottom. 4. Attach one of the fuse taps to pin 86 of the relay. Bend the tap to conform to the bottom of the relay. Use a piece of electrical tape to hold the wire to the side of the relay. 5. Return the relay to position #12 and run the other end of the wire to the top of the fuse panel. 6. Remove the Fog light fuse, 25 Amp, #7 (top row, 4th position from the right) from the fuse panel. Slip the fuse tap on the wire end to the upper leg of the fuse. 7. Return the fuse with the tap up into position #7. |
Sounds interesting. If you get it to work on your 997, let us know.
Originally Posted by Harvey in MD
(Post 2548202)
DRL-Fog Light Hack
The hack involves a single jumper wire between the Fog light relay and the Fog light fuse. Now the Fog lights go on and off with the ignition switch and are switched off when the high beam headlights go on. |
