Gas Pedal Not Working! Safety Issue, Help!
Old Dec 29, 2010 | 07:34 AM
timod1441's Avatar
timod1441 is infamous around these parts
Smile Hello
Hello!
Old Dec 29, 2010 | 07:57 AM
DÜnkleblau S's Avatar
DÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant future
Fuel pump? In any case, have it towed if u can't get to the shop
Old Dec 29, 2010 | 08:11 AM
timod1441's Avatar
It happens maybe once a day at a random time...so the car is functional but just risky! I had suspected the fuel pump as well but don't think it's that...
Is there a known software patch for this maybe?
Thanks for your help.
Old Dec 29, 2010 | 08:17 AM
chance6's Avatar
chance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to beholdchance6 is a splendid one to behold
This is a 'drive-by-wire' car, so that means electronically modulated throttle position, right ? So they need to do a run-through of the software / control system.
Old Dec 29, 2010 | 09:27 AM
timod1441's Avatar
Thanks for the input.
Any other suggestions? I've seen this issue elswhere on the forum but nobody has posted the solution.
Thanks again in advance.
Old Dec 29, 2010 | 10:25 AM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Like chance said, the drive-by-wire system needs to be examined thoroughly. Maybe one of the sensor has gone bad, possibly the one the pedal is connected to.
Old Dec 29, 2010 | 10:51 AM
T33's Avatar
T33
T33 is infamous around these parts
Drive by wire cars have sensors on the gas pedal. I had the same issue with my Mercedes. All they had to do was change the gas pedal. I don't know if it would be the same with Porsche. I suspect it should be the same.
Old Dec 29, 2010 | 11:20 AM
Hella-Buggin''s Avatar
Hella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud ofHella-Buggin' has much to be proud of
Hurry before it turns into a runaway prius!
Old Dec 29, 2010 | 12:24 PM
timod1441's Avatar
Thanks T33, I will check this as well.
Any other suggestions guys/gals?
Old Dec 29, 2010 | 12:50 PM
stevepow's Avatar
stevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of lightstevepow is a glorious beacon of light
Originally Posted by timod1441
Mechanic checked the computer and nothing comes up. He cleaned the throttle body but that didn't solve it.
Please help! Thanks in advance!
Is this a Porsche service center or independent? At any rate, maybe try to find someone else to look at it.
Old Dec 29, 2010 | 01:44 PM
timod1441's Avatar
Independent, but I am taking it to a dealer center on Monday - but I mentioned the problem to the dealer tech already over the phone and he also seems clueless!
I'm bringing all your messages to him though to see if anything rings a bell.
Thanks, any other ideas?
Old Dec 29, 2010 | 03:42 PM
T33's Avatar
T33
There is an article about Drive by Wire. Here's the link below. Hope this helps.
http://www.ehow.com/about_5645691_pr...-throttle.html
Old May 14, 2014 | 01:17 PM
996electric's Avatar
996electric is infamous around these parts
Pinout accelerator pedal 997
Hi,
Im searching for the pin out of the 997 accelerator pedal. Can anyone help me?
Looks like a hall effect sensor in the throttle, I could not read a resistance, just infinity between all connectors.
Old May 14, 2014 | 01:23 PM
Buddhamonk's Avatar
Buddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura aboutBuddhamonk has a spectacular aura about
You bring back a thread from 2010 to ask for a pin?
Old May 14, 2014 | 01:34 PM
Hi,
why not, the content is similar
