durametric problems
Old Feb 17, 2011 | 11:33 PM
911 Molar's Avatar
911 Molar is infamous around these parts
durametric problems
Hi guys,
Installed Ver 6 beta and corresponding USB drivers.
Plug cable into OBD 2 port and computer and program will not work.......
"cable not ready"
I run a windows 7 prof 64 bit.....
Any ideas ?
Old Feb 18, 2011 | 01:29 AM
jorisctn's Avatar
jorisctn is infamous around these parts
Originally Posted by 911 Molar
Hi guys,
Any ideas ?
Hi 911 Molar,
Connect cable to OBDII port in your car and switch contact on.
Verify that the green LED on the connector is on.
Connect the cable to the USB port on your computer.
Then start the Durametric program.
Hope this helps,
Joris
Old Feb 18, 2011 | 08:20 AM
Dharn55's Avatar
Dharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud ofDharn55 has much to be proud of
Do you have the latest cable. Older versions like mine, which was one of the original ones, won't work with 6xx and beyond. If you have the older cable version Durametric will sell you the newer cable for $150, you have to send the old cable in first.
Old Feb 18, 2011 | 06:13 PM
911 Molar's Avatar
all sorted.
Turn ignition on twice (2), followed by hazard lights.
plug in and then open durametric.
Prrrrrrrrrrfect
drug delivery
Oct 24, 2015 11:04 PM
vogz
Sep 19, 2015 01:02 PM
jdbaker
Sep 19, 2015 10:34 AM
arhim22
Sep 7, 2015 08:49 PM
